Full Version: Playback issue on OS X Mavericks with 12.3!
I have got this playback issue since 12.1 I think, and now I need help to sort this bug out!
I have a debug log here: http://pastebin.com/YLzcyYup. And when I tried to play the movie Pain And Gain it started to stutter, glitch and all kinds of stupid stuff. Stopped the movie, turn on the debug and tried again to see what the hell is happening! The FPS i as low as 4 FPS when this happens, and to fix it for the moment I need to shut of XBMC and then start it again.
Any clues?
You have cut the log - that doesn't help much.
Check your audio settings. Set it to 2.0 (YES!) and disable LPCM. If you want to have 5.1 audio and your amp supports it - enable AC3/DTS capable receiver.
(2014-01-17, 15:19)Memphiz Wrote: [ -> ]You have cut the log - that doesn't help much.
The log is cut because the info before that day is unimportant. So you think is the soundsettings that are making this issue?
The startup information is very important. It tells us hardware information, audio information, exact version numbers, possible conflicting add-ons, if the databases set up correctly or not, and a lot more.
And yes, audio settings can cause exactly what you are describing.
Please see this log for more info then: http://pastebin.com/enGcHGkM Smile
