Full Version: Where is the definition of XBMC.Suspend() and so on?
The powering down menu is not fully working as I would like it to do. Particularly for suspend
I have a script that is directly bound to the remote and it works well, whereas the menu choice
suspend does not. I do not know what commands xbmc is trying to use when suspending, but
I would like to check and change those.
I have been going through the google on this and the only thing that I have found is changing
directly the onclick command in the DialogButtonMenu.xml for the skin. Does not this mean that
the change applies only to this skin? Is there no way to define the actions centrally for the builtin
commands like XBMC.suspend()?
