Full Version: CuBox-i SPDIF out format issue
Hello,
I'm running latest version of geexbox on CuBox-i (geexbox-devel-20140114-r16709.cuboxi). The issue is I can't set fixed format bit rate for SPDIF (optical) output in XBMC. My stereo receiver is capable of receiving PCM 16-bit signal only and XBMC is using 24-bit (24_LE).
I've tried to test the output via the command line and it's working when output format is set to S16_LE.
Command used: speaker-test -Ddefault -c2 -fS16_LE
Could somebody help me with this issue?
Thank you in advance.
