Full Version: Engadget script failed: plugin.video.engadget
Hi all,
I recently installed XBMC Frodo on my Apple TV 2 running the newest Seas0nPass tetherless jailbreak with Apple TV 5.3.
I installed a few Video add-ins, one of them being Engadget, version 1.0.4.
When I try to open the Engadget plugin I'm getting the message Error Script failed! : plugin.video.engadget and the plugin doesn't load. Huh
I've turned on debugging and viewed the error in the log file which I will paste below.
There seems to be an issue with Beautiful Soup and Python's built-in HTMLParser not playing nicely.
Next I tried installing the suggested external HTML parsers to make it work but I've gotten nowhere. Confused
Finally I tried checking for a newer version of the Engadget plugin but it seems 1.0.4 is the latest, I even checked divingmule's github repo and compared the default.py script to what was most recently posted on github.
I'm out of ideas here and about to give up, but maybe somebody else knows a solution to this error, or maybe it's time for an update to the Engadget add-on script.
Thanks for any help or ideas! Big Grin
apt-get install lxml
E: Couldn't find package lxml
apt-get install python-lxml
E: Couldn't find package python-lxml
pip install lxml
-sh: pip: command not found
apt-get install html5lib
E: Couldn't find package html5lib
apt-get install libxml2-dev
E: Couldn't find package libxml2-dev
Debug Log:
12:58:29 T:113946624   DEBUG: CGUIMediaWindow::GetDirectory (plugin://plugin.video.engadget/)
12:58:29 T:113946624   DEBUG:   ParentPath = [addons://sources/video/]
12:58:29 T:805117952   DEBUG: StartScript - calling plugin Engadget('plugin://plugin.video.engadget/','1','')
12:58:29 T:805117952    INFO: initializing python engine.
12:58:29 T:805117952   DEBUG: new python thread created. id=3
12:58:29 T:805117952   DEBUG: WaitOnScriptResult - waiting on the Engadget (id=3) plugin...
12:58:29 T:147161088   DEBUG: Python thread: start processing
12:58:29 T:147161088  NOTICE: -->Python Interpreter Initialized<--
12:58:29 T:147161088   DEBUG: Process - The source file to load is /var/mobile/Library/Preferences/XBMC/addons/plugin.video.engadget/default.py
12:58:30 T:147161088   DEBUG: Process - Setting the Python path to /var/mobile/Library/Preferences/XBMC/addons/plugin.video.engadget:/var/mobile/Library/Preferences/XBMC/addons/script.module.simplejson/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.beautifulsoup4/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.brightcove/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.beautifulsoup/lib:/private/var/stash/Applications/XBMC.frappliance/XBMCData/XBMCHome/addons/script.module.pil/lib:/var/mobile/Library/Preferences/XBMC/addons/script.common.plugin.cache/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.simple.downloader/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.requests/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.buggalo/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.parsedom/lib:/var/mobile/Library/Preferences/XBMC/addons/script.module.xbmcswift2/lib:/var/stash/Applications/XBMC.frappliance/Frameworks:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python26.zip:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-darwin:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/plat-mac/lib-scriptpackages:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-tk:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-old:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/lib-dynload:/var/stash/Applications/XBMC.frappliance/Frameworks/lib/python2.6/site-packages:
12:58:30 T:147161088   DEBUG: Process - Entering source directory /var/mobile/Library/Preferences/XBMC/addons/plugin.video.engadget
12:58:30 T:147161088   DEBUG: Instantiating addon using automatically obtained id of "plugin.video.engadget" dependent on version 2.1.0 of the xbmc.python api
12:58:30 T:113946624   DEBUG: ------ Window Init (DialogBusy.xml) ------
12:58:32 T:147161088   DEBUG: [plugin.video.engadget-1.0.4]: {}
12:58:32 T:147161088   DEBUG: [plugin.video.engadget-1.0.4]: Request URL: http://www.engadget.com/videos
12:58:35 T:147161088   ERROR: /var/mobile/Library/Preferences/XBMC/addons/script.module.beautifulsoup4/lib/bs4/builder/_htmlparser.py:155: RuntimeWarning: Python's built-in HTMLParser cannot parse the given document. This is not a bug in Beautiful Soup. The best solution is to install an external parser (lxml or html5lib), and use Beautiful Soup with that parser. See http://www.crummy.com/software/BeautifulSoup/bs4/doc/#installing-a-parser for help.
                                              "Python's built-in HTMLParser cannot parse the given document. This is not a bug in Beautiful Soup. The best solution is to install an external parser (lxml or html5lib), and use Beautiful Soup with that parser. See http://www.crummy.com/software/BeautifulSoup/bs4/doc/#installing-a-parser for help."))
12:58:35 T:113946624   DEBUG: ------ Window Init (DialogKaiToast.xml) ------
12:58:35 T:147161088    INFO: Python script stopped
12:58:35 T:805117952   DEBUG:  WaitOnScriptResult - plugin exited prematurely - terminating
12:58:35 T:113946624   ERROR: GetDirectory - Error getting plugin://plugin.video.engadget/
12:58:35 T:113946624   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.engadget/) failed
12:58:35 T:113946624   DEBUG: CGUIMediaWindow::GetDirectory (addons://sources/video/)
12:58:35 T:113946624   DEBUG:   ParentPath = []
12:58:36 T:113946624   DEBUG: waiting for python thread 3 (/var/mobile/Library/Preferences/XBMC/addons/plugin.video.engadget/default.py) to stop
12:58:36 T:113946624   DEBUG: python thread 3 (/var/mobile/Library/Preferences/XBMC/addons/plugin.video.engadget/default.py) destructed
Specs:
Apple TV 2 (black)
XBMC 12.3 Frodo
Seas0nPass 0.9.5
Apple TV software 5.3 (6105)
Engadget, Video add-on 1.0.4
Anybody have any ideas?
It would be best to report this directly to the Engadget add-on forum thread: http://forum.xbmc.org/showthread.php?tid=178562
Thanks Scott, good idea, I'll try that!
Still looking for a solution to this...
