Full Version: How to change alert ratio?
Snes Roms launch in wide screen? How to set 4:3?
Thank you Big Grin
I think that is shares the setting with regular videos, so if you have 4:3 movies and TV shows set to fill the screen then the games will too.
Tomkun - You're the boss! Thanks for the advice.
Your tip worked but it has to be set for all roms for some reason... either way everything isnt blown out of aspect like before.
Thanks! Smile
You're welcome.
