2014-01-20, 21:03
Changing to OpenElec has been a significant improvement over the Windows build that I was using in terms of stability, But I am having troubles I have never encountered before, some seasons of tv shows are not showing up when XBMC scans for content...
I am currently using OE 3.2.4, the latest stable build.
My NAS file structure is set up like
SMB
...TV Shows
........Show 1
..............Season 1
...................Episode 1...
..............Season 2
.........Show 2....
Nothing complicated about it. All of my episodes are within season folders. XBMC is set to flatten TV shows with only one season.
What I am experiencing is (as an example) Criminal Minds which has 9 seasons, only finds 8 of them. Season 9, which is right where it should be on the server isn't added to the library. Elementary (2 seasons) only finds season 1...
I have tried removing all sources, cleaning the database, and re-adding the sources. The same problems persist. I was not having this issue when I was using Windows. That said, going back to Windows isn't about to happen.
I would appreciate any advice you can offer
SMB
...TV Shows
........Show 1
.........Show 2....
