Full Version: ToggleFullScreen with profiles
Running the 18th nightly on Windows I cannot switch to full screen in my "profile". As "Master User" there is no issue.
Logs don't show much
22:28:52 T:10112 DEBUG: CApplication::OnKey: backslash (0xf05c) pressed, action is ToggleFullScreen
22:28:52 T:10112 DEBUG: ------ Window Deinit (Pointer.xml) ------
22:28:52 T:10112 DEBUG: Keyboard: scancode: 0x2b, sym: 0x005c, unicode: 0x005c, modifier: 0x0
22:28:53 T:10112 DEBUG: Keyboard: scancode: 0x2b, sym: 0x005c, unicode: 0x005c, modifier: 0x0
22:28:53 T:10112 DEBUG: CApplication::OnKey: backslash (0xf05c) pressed, action is ToggleFullScreen
Martin
have you locked the settings for your profile? Just tested by creating a new profile (separate database, no settings locked) and it's working fine.
No. Basically the difference is I have two profiles, Master User with PVR enabled and my normal account with it off. I tried using a keymap.xml in the profile no change. No change with the 20th build.
Martin
ah, right, using the backslash or ALT+RETURN doesn't work when using a profile. Doing it via settings does work though. That's odd. Mind creating a bugreport in our bugtracker? http://trac.xbmc.org (please check if such a ticket is not already present)
No problem I will write it up this evening.10 hrs.or so.
Edit: Ignore it I guess, I went back to 12.3 to confirm a good version it worked and then and trying through trial and error to determine which version worked, I couldn't duplicate. Even yesterday's and today work again.
Martin
