Full Version: Configure peripherals through RPC
Hi All!
Is it possible to configure peripherals through JSON RPC just like I can do via [Settings - System - Input Devices - Peripherals - Edit]?
Basically I want to disable some peripherals from scripts when my TV is off or when other source is active ().
I was trying to find peripheral settings in GetSettings/SetSettings methods, but no luck.
Any help on how to do that is appreciated.
Unforunately peripherals configuration is implemented completely independent of the other settings in XBMC so you can't access those through the methods in the Settings namespace. Right now there's no way to do what you want.
