2014-01-22, 14:44
Hello, I posted this in the general Help and Support forum but with no responses it soon shot down the listings, so hopefully someone here may be able to help..
In thread http://forum.xbmc.org/showthread.php?tid=181164 is a discussion on a problem whereby a live .wtv file is remuxed to a .ts file and the correct audio stream is identified and the other discarded.
When watching recordings they are not remuxed, the .wtv file is just played in xbmc (remuxing messes up ability to fast forward properly), however there are 2 english,(stereo) streams and the default one which is selected is often the visually impaired (SAP) stream.
My understanding is that ffmpeg code can identify the correct stream but there may need to be some logic added to select it properly in xbmc? Is this the case?
