2014-01-24, 05:54
I have added about 30 movies into XBMC.
When I am on the Main Menu of XBMC and then select movies, I've noticed that many of the movie titles have been duplicated. If I select one of the two names, it will work, the other says "This file is no longer available. Would you like to remove it from the library?"
I have tried updating the library to see if I can remove the duplicate names, but that didn't work.
I had two questions:
1. How did I end up with two listings for most movies with one working and the other not?
2. Instead of cleaning up the library one file at a time, how can I more effectively clean up the library to remove the duplicate names?
Thank you
Thank you
