I have had a problem for the last few months with EMM not scraping TV shows. I rightt click the show and select (re)scrape show and the window pops up but there is no "OK" or "Cancel" button in the lower right corner. I put a check mark in manual and the buttons appear, as soon as I enter the number from TVDB, the buttons disappear. I have the latest version of EMM, running on Win 7 64 bit. The problem started shortly after arriving in Kuwait. Since I use VPN for almost everything I can't imagine my location would have anything to do with it.
Movies scrape just fine.
Please upload a screenshot.
The OK button is covert by plot field. This error had anyone ever.
Do you have enabled any zoom settings in Windows?
Not as far as I can tell. Like I said, older tv shows I have and movies work just fine.
have you tried to change the resolution in windows?
try a couple of different resolutions.
I have played with resolutions and zoom. It doesn't change anything
I'm having this exact same issue, not being able to see the OK button, also played with resolutions and zoom and no change.
I think I know the bug =)
I will check this today.
I have not found the actual error.
But I have now placed the buttons in the foreground.
Overwrite the original file in .\Ember\Modules:
Fix for Ember 1.3.0.18
Excellent! So far it is working like a champ! Thank you!
Wow, I stated this issue a long time ago and was ignored. Thanks very much.[/i]
(2014-02-09, 13:08)JapanDave Wrote: [ -> ]Wow, I stated this issue a long time ago and was ignored. Thanks very much.[/i]
I'm sorry
(2014-02-09, 19:40)DanCooper Wrote: [ -> ] (2014-02-09, 13:08)JapanDave Wrote: [ -> ]Wow, I stated this issue a long time ago and was ignored. Thanks very much.[/i]
I'm sorry
No need to apologize, since the program is free and all the hard work was done by you. I just hoped that this problem could have been found sooner.
I was PUI last night, so please forgive my bad behavior.
Hi. I hope I'm in the right thread (meaning it's still alive). I didn't find any appropriate thread in the bug tracker, so I'm posting here.
There's indeed something wrong with scraping TV shows. I'm not sure if that is caused by eventual changes made by TVDB people, or something in Ember itself.
Here's the error log from my EMM session (latest 1.4.0.0 x86 beta):
Quote:================= <Assembly Versions> =================
Platform: x86
Ember Application (Revision: 1.4.0.0)
Ember API (Revision: 1.4.0.0)
IMDB_Data (Revision: 1.4.0.0)
MoviepilotDE_Data (Revision: 1.4.0.0)
OFDB_Data (Revision: 1.4.0.0)
TMDB_Data (Revision: 1.4.0.0)
FanartTV_Poster (Revision: 1.4.0.0)
IMDB_Poster (Revision: 1.4.0.0)
IMPA_Poster (Revision: 1.4.0.0)
MPDB_Poster (Revision: 1.4.0.0)
TMDB_Poster (Revision: 1.4.0.0)
GoEar_Theme (Revision: 1.4.0.0)
IMDB_Trailer (Revision: 1.4.0.0)
TMDB_Trailer (Revision: 1.4.0.0)
TVDB Data Poster (Revision: 1.4.0.0)
TelevisionTunes_Theme (Revision: 1.4.0.0)
Renamer (Revision: 1.4.0.0)
Frame Extractor (Revision: 1.4.0.0)
Genres Editor (Revision: 1.4.0.0)
Media File Manager (Revision: 1.4.0.0)
Media Sources Editor (Revision: 1.4.0.0)
Audio & Video Codec Mapping (Revision: 1.4.0.0)
Movie List Exporter (Revision: 1.4.0.0)
Notifications (Revision: 1.4.0.0)
Trakt Settings (Revision: 1.4.0.0)
time;logger;callsite;threadid;level;message
2014-06-06 11:15:06.6613;EmberAPI.HTTP;EmberAPI.ErrorLogger.Error;1;ERROR;"<http://thetvdb.com/api/353783CE455412FD/series//all/en.zip>The remote server returned an error: (404) Not Found.
at System.Net.HttpWebRequest.GetResponse()
at EmberAPI.HTTP.DownloadZip(String URL)"
Maybe it's the double slash after "/series"?
Version 1.3.0.20 doesn't scrape anymore as well. Error log from this version:
Platform: x86
Ember Application (Revision: 1.3.0.20)
Ember API (Revision: 1.3.0.20)
Ember Extras Scraper (Revision: 1.3.0.12)
Ember Native Movie Scrapers (Revision: 1.3.0.19)
Ember TMDB Movie Scrapers (Revision: 1.3.0.18)
Ember XML Scraper (Revision: 1.3.0.5)
Renamer (Revision: 1.3.0.12)
Frame Extractor (Revision: 1.3.0.12)
Media File Manager (Revision: 1.3.0.5)
Movie List Exporter (Revision: 1.3.0.12)
NMT Jukebox Builder (Revision: 1.3.0.13)
Notifications (Revision: 1.3.0.14)
Offline Media Manager (Revision: 1.3.0.15)
XBMC Controller (Revision: 1.3.0.5)
Boxee Compatibility (Revision: 1.3.0.12)
MediaBrowser Compatibility (Revision: 1.3.0.12)
YAMJ Compatibility (Revision: 1.3.0.12)
Genres Editor (Revision: 1.3.0.12)
Media Sources Editor (Revision: 1.3.0.12)
Audio & Video Codec Mapping (Revision: 1.3.0.12)
Trakt Settings (Revision: 1.3.0.12)
Ember Native TV Scrapers (Revision: 1.3.0.19)
Title: Error
Message: The remote server returned an error: (404) Not Found.
StackTrace: at System.Net.HttpWebRequest.GetResponse()
Date/Time: 6.6.2014. 11:07:54
Maybe I'm missing something. Any suggestion will be much appreciated (I would like to avoid erasing everything, though
). Thank you in advance.
My hardware & software:
Intel NUC DC3217IYE (8GB RAM, 60GB SSD, wired ethernet, FLIRC), Windows 7 Pro 64bit, XBMC Gotham 13.1
