this is an addon for
ulive.com
Watch full episodes and clips from Food Network, Cooking Channel, HGTV, Travel Channel, and DIY.
Install from my
testing-repo.
Any feedback is welcome...
Have fun!
So far I've tried it with a full episode of Samantha Brown's Passport to Europe and it works great! Thank you so much!
Thanks for the addon, I thoink though you should state this only work sin the US , so geo restricted.
(2014-01-26, 19:08)sheilnaik Wrote: [ -> ]So far I've tried it with a full episode of Samantha Brown's Passport to Europe and it works great! Thank you so much!
(2014-01-26, 19:18)privado Wrote: [ -> ]Thanks for the addon, I thoink though you should state this only work sin the US , so geo restricted.
Thank you both for the feedback. And yes, full episodes are only working in the US. Most clips should not be geoblocked.
(2014-01-26, 03:52)AddonScriptorDE Wrote: [ -> ]Hi,
this is an addon for ulive.com
Install from my testing-repo.
Have fun!
Great plugin!! Thanks
cordfree: brilliant, thanks. works like a charm here. Thanks AddonScriptorDE!
Why does it automatically repeat the episode played ?
(2014-02-27, 18:39)phileas50 Wrote: [ -> ]Why does it automatically repeat the episode played ?
It doesn't! Check your xbmc settings, you obviously have it on repeat...
I downloaded the Repo and installed it but when I went into the repo there was nothing there no addon. Did I miss a step?
Ah, thanks. Didn't know you could do that.
Sorry if this seems like a lame question.........but I'm new to XBMC. How do I add (or where do I find) your "test" repository? I'm running FRODO on ATV2.
Does this have a proxy settings menu?
