Full Version: Andriod TV Box
Hi, Just after a bit of help setting up the audio for my android MX stream box and I am pretty new to this
Within XBMC under system and settings I have been reading there is supposed to be a left hand menu which can change the level from basic to expert or advanced. I don't appear to have this menu (Firstly how would I go about getting this if possible) The reason I am after this is I can get my audio to play through my surround sound system but it will play through TV (Which is not too good) Also noticed when I go into system, audio output I don't have all the options.
The box is using Frodo 12.2
Anthony
Frodo don't had settings level only Gotham,
The audio selection on Frodo is under settings-system-audio output
Hi Warlion,
Thanks for the response, I found the audio settings but can't change much as there isn't much to change, I am wanting to send the audio through SPDIF rather the HDMI but can't change it. Do you know of any way I can do this in Frodo or do you think it's best to upgrade to Gotham?
Thanks again
Anthony
That's weird, had to be directsound: spdif -Audio digital or wasapi: spdif
Perhaps that Frodo is some how modify why don't upgrade to official Frodo 12.3?
http://xbmc.org/download/
