Full Version: Video Add On problem using XBMC Remote from Ipad
I am not sure if this is the correct forum to post my query, but would like to ask for some help please. I have recently obtained a Raspberry Pi and installed RASPBMC on it. My main use is for Video catchup and being in the UK I mainly use Iplayer.
Everything is working fine when I use a normal remote control with it.
I then added XBMC Remote to my Ipad to control it from there but when using the XBMC Remote control again it is working ONLY if I pick the Remote Control option on the IPAD.
There are however other options that I have tried to get to work on the XBMC Remote on the Ipad that will not. If I select the icon on the IPAD for video add-ons I can see the full list of Iplayer TV shows on the IPAD. I can then select on the IPAD the TV show I want and it will start to run on the TV from the Rasberry.
So far so good .. however I cannot then find any way to stop the program or exit from it .. or do anything else on Raspberry XBMC if I take this route.
I lose all control of the raspberry pi as it completely hangs!
Does anyone know what I need to do to fix this please?
