2014-01-27, 00:45
Is there a way to remove Genres from the selection list? I disabled languages and/or deleted. They still stay. If I add a custom, it can never be deleted.
Ideas?
Ideas?
(2014-01-27, 18:10)hatbrox Wrote: [ -> ]I think I had some issues a long time ago with the genre editor.
At the end, I resorted modifying the genres.xml file directly as I found it much quicker to remove all unneeded languages and genres.
The only problem is that sometimes the scrapper fetchs a genre that you no longer use, (e.g. Sci-Fi versus Science Fiction) so don't forget to quickly check what the scapper fetched.
HB.
PS:
By the way, when you update EMM, keep a copy of this xml before you apply the update, else you will loose it.
