Full Version: Multiple players on Retroplayer?
My apologies if this has been asked before...
How would I configure multiple players for RetroPlayer? I know the controls A/S/Z/X work for Player 1, but I can't figure out how to configure Player 2? I'm trying emulation on SNES.
If it matters, my end goal is to configure the keyboard for players 1 and 2, and then use Joy2Key to configure the gamepads. It seems easier to do this than to mess around with keyboard.xml, but if editing the xml file is the best way to do it, can someone explain how or give a sample xml file?
Thank you!!!
Sheil
Hi!
For me multiplayer is only working with one device per player (e.g default keyboard configuration for one player and the gamepad for the other one). Take a look at this post to setup your controls. I also had problems with the SNES9x emulator but the SNES9x-next worked just fine. The xbmc debug output may be helpful to you.
