Full Version: skin.confluence
I've seen this question before, but no useful answer (that I've found anyway)
After installing the the latest Frodo build for ARM on my RKM802iv I've been trying to make the artist slideshow working, as I did with no probs on PC. But I am simply not able to find the skin.confluence folder. If I install another skin, the skin.ANYSKIN folder shows up as expected.
This also goes for the latest nightly build.
If I've missed the correct thread, kindly direct me to it.
Thanks...
Are you using a file browser that has a "show hidden files" option? To get to the skin.confluence folder in the addon folder you need to be able to see hidden files (they have a . in front for example .data, these files are not normally visible. ES File Explorer is an excellent choice.
