2014-01-27, 14:55
Hi all,
I am new to this forum, so please correct me, if this is the wrong forum or if I should open a ticket on trac directly.
I think I have encountered an issue with improper escaped filenames: When I try to cleanup the music database the cleanup process will be aborted and the following error is logged in xbmc.log:
I guess the problem is the apostroph in the artist's name. More precise it seems to be an "turned comma" (UTF8: 0xcabb) in this case. At least it is printed in the log file as such.
I am using xbmc nightly builds on Ubuntu. Current installed version: 3:12.9.12-git201401191726~0af940a-1~ppa1~saucy.
I did a short search on the forum and found same related threads, e.g.
Clean Music Library Failure, but found no indication that there is an open ticket.
Best regards,
Sven
ERROR: SQL: Undefined MySQL error: Code (1267)
Query: select count(idPath) from songpaths where SUBSTR(strPath,1,44)='/repository/music/m4a/Israel Kamakawiwoʻole/'
Best regards,
Sven
