Full Version: moving XBMC
Hi there,
It's possible to move XBMC from my iMac to my MacBook with all add ons and configurations?
How? Huh
Thank you very much.
Rik
Install the same build of XBMC on the other box and copy over the userdata folder.
http://wiki.xbmc.org/?title=Userdata
(I presume its the same for a mac, it works on both Linux and Windows )
Thank you very much,
Yes but I cannot find the folder "/Users/<your_user_name>/Library/Application Support/XBMC/userdata/"
It's in ~/Library/Application Support/XBMC. The user library folder is hidden, but from Finder pull down the "Go" menu while pressing the "Option" key and Library should be one of your choices (depending on your OS).
I'd copy the entire "XBMC" folder, and then you get the add-ons in addition to the settings. As long as it's the same OS, you should be fine.
Thank you all!!!
