2014-01-27, 21:51
2014-01-27, 21:55
2 options, create one theme, go to settings, skin setttings, themes, my theme, and set path for folder, other option go to setting, select customize main menu, option, for each item in main menu is possible set your image/images.
2014-01-27, 21:56
Go to the settings sub menu > choose 'customize main menu' > then highlight the button you want to change the fanart of (e.g Movies) > to the right a list of options will appear. You'll find what your looking for there.
Edit: lol, you beat me to it Wanilton
2014-01-27, 21:58
don´t worry, it´s fine...your instruction is more clearly...
2014-01-27, 22:02
cheers guys i found it
im finally getting around to aeon MQ iv always went back to aeon nox lol
also where is the file located with the return picture logo
when im browsing movies when i get to the end of the list
i get the box with the arrow pointing up to return
id like to change that
