Having problem with OSX Mavericks and xbmc 12.3 starting the program, and then it crashes.
crash file here
http://pastebin.com/wZj7vW0i
Best regards
STTS
Your database is corrupt (you should find someting in the wiki on how to correct this).
I think there is, but it's in the iOS FAQ. Basically, go into the
userdata folder (wiki) (see the
Mac FAQ (wiki) on how to find it, since OS X will hide your Library folder), and then go into the Database folder and probably just nuke all the files in there. You'll have to set up your library again, though.
(2014-01-29, 01:39)Ned Scott Wrote: [ -> ]I think there is, but it's in the iOS FAQ. Basically, go into the userdata folder (wiki) (see the Mac FAQ (wiki) on how to find it, since OS X will hide your Library folder), and then go into the Database folder and probably just nuke all the files in there. You'll have to set up your library again, though.
thanx m8 will try that in a few hrs when i get back home.
replay then here if it works
/best regards
STTS
Thanx Ned Scott
You where right on the money,
Having the same issue with Mavericks and 12.3.
http://pastebin.com/LnNqaf5B
I deleted the database files as suggested to STTS, however I still have the issue.
Any thoughts?
All the Best
JChou
don't cross post - your crash cause is completly different (and unknown to me too - in case you ask)
