Full Version: Can't Install XBMC on Mac Mini
I can download the app from the XBMC website, but when i try and open it. It says this is from an unauthorised developer, do you still want to open it, so i say yes. But still nothing, just keeps popping up another message saying failed to open, would you like to re-try, send report to apple or ignore.
Here is the spec of my machine:
Mac OS X
Version 10.5.8
Pocessor 2 GHz-Intel Core 2 Duo
Memory 512 MB 667 MHz DDR" SDRAM
Startup Disk Mini
Any help would be much appreciated.
Right click (or command+click) the XBMC icon and select "open"
(2014-01-28, 21:12)Walt74 Wrote: [ -> ]Right click (or command+click) the XBMC icon and select "open"
Tried that buddy.
would have been to easy Smile Which version of XBMC are you trying to use ?
What version of xbmc? Anything after 11.x (Eden) will require at least OSX 10.6.
I recommend 10.6.8 Snow Leopard.
(2014-01-28, 21:21)wgstarks Wrote: [ -> ]What version of xbmc? Anything after 11.x (Eden) will require at least OSX 10.6.
i was trying to get to this Big Grin
i don't know what version, any that will work.
(2014-01-28, 22:41)1982ollie Wrote: [ -> ]i don't know what version, any that will work.
Try Eden (version 10).
eden is 11
(2014-01-29, 21:45)Memphiz Wrote: [ -> ]eden is 11
My bad. Yes 11.
