Full Version: SCRIPT ERROR Apple iTunes Podcast
I have been playing with having multiple XBMC instances access a central server for library synchronization. The library syncs all fine. However now the iTunes Podcast plugin is failing.
I am getting Script Error addon.py error messages.
I deleted the userdata folder to try reset my main xbmc to factory settings and added this advanced.settings.xml so that the library synched again.
<advancedsettings>
    <videodatabase>
        <type>mysql</type>
        <host>192.168.LEFTOUT</host>
        <port>3306</port>
        <user>xbmc</user>
        <pass>xbmc</pass>
    </videodatabase>
    <musicdatabase>
        <type>mysql</type>
        <port>3306</port>
        <user>xbmc</user>
        <pass>xbmc</pass>
    </musicdatabase>
     <videolibrary>
          <importwatchedstate>true</importwatchedstate>
     </videolibrary>
<pathsubstitution>
  <substitute>
    <from>special://profile/sources.xml</from>
    <to>smb://192.168.LEFTOUT/userdata/sources.xml</to>
  </substitute>
</pathsubstitution>
</advancedsettings>
This is the error in the log file. .
00:01:16 T:3040731136  NOTICE: Previous line repeats 4 times.
00:01:16 T:3040731136 WARNING: GetLabel - Unknown nodetype requested 0
00:01:16 T:2913748032 WARNING: Previous line repeats 1 times.
00:01:16 T:2913748032  NOTICE: Thread Background Loader start, auto delete: false
00:01:18 T:2913748032  NOTICE: Thread XBPyThread start, auto delete: false
00:01:18 T:2913748032  NOTICE: -->Python Interpreter Initialized<--
00:01:23 T:2913748032   ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
                                            Error Type: <type 'exceptions.SystemError'>
                                            Error Contents: dynamic module not initialized properly
                                              File "/home/pi/.xbmc/addons/plugin.video.itunes_podcasts/addon.py", line 21, in <module>
                                                from resources.lib.api import \
                                              File "/home/pi/.xbmc/addons/plugin.video.itunes_podcasts/resources/lib/api.py", line 24, in <module>
                                                import feedparser
                                              File "/home/pi/.xbmc/addons/script.module.feedparser/lib/feedparser.py", line 199, in <module>
                                                xml.sax.make_parser(PREFERRED_XML_PARSERS) # test for valid parsers
                                              File "/usr/lib/python2.7/xml/sax/__init__.py", line 81, in make_parser
                                                return _create_parser(parser_name)
                                              File "/usr/lib/python2.7/xml/sax/__init__.py", line 105, in _create_parser
                                                drv_module = __import__(parser_name,{},{},['create_parser'])
                                              File "/usr/lib/python2.7/dist-packages/drv_libxml2.py", line 67, in <module>
                                                import libxml2
                                              File "/usr/lib/python2.7/dist-packages/libxml2.py", line 1, in <module>
                                                import libxml2mod
                                            SystemError: dynamic module not initialized properly
00:01:23 T:3040731136   ERROR: GetDirectory - Error getting plugin://plugin.video.itunes_podcasts/?content_type=audio
00:01:23 T:3040731136   ERROR: CGUIMediaWindow::GetDirectory(plugin://plugin.video.itunes_podcasts/?content_type=audio) failed
00:01:23 T:3040731136 WARNING: GetLabel - Unknown nodetype requested 0
00:01:23 T:2913748032 WARNING: Previous line repeats 1 times.
00:01:23 T:2913748032  NOTICE: Thread Background Loader start, auto delete: false
Is there a way i can fix this?
Is there a way i can reset xbmc to factory settings?
