Just got this working with WMC. EPG shows up no problem with all show names all the way out to 14 days. However, I get no detail information that I would from WMC. Is this not available or is something not set up correctly?
Thanks all.
Gregg
If you click on the show in the EPG, do you then see the details you wanted? If so then the data is there. Then it's just down to what skin you use in XBMC as to how the data is displayed. Also in Gotham (XBMC 13) which is the next future version, the default XBMC skin (confluience) for LiveTV does include details of the currently highlighted EPG item, in a panel at the bottom of the screen below the EPG grid. You can run Gotham nightly builds if you dont mind being on the cutting edge. Otherwise in Frodo (12.3, stable) find a skin that's more to your liiking than the default Confluence
If I misunderstood your question please clarify it, and post a screenshot or ServerWMC log (to pastebin, check the forum guidelines for posting logs/asking for help etc)
Hi Scarecrow - No I do not see the information even if I click on the show. So must be some type of server error? I will set up logging and see what it shows.
what OS is your client on? If it is a remote lcient (ie not running locally alongside ServerWMC), check that the client and server clocks are in sync... the EPG request from client to serverWMC says "give me the EPG entries for channel X between now and X hours from now" so if it's idea of "nbow" is different to the server, then the server may not have anyEPG data to suit that time period.
Also, what specifically is the data that's in wmc that you are missing in xbmc?
