2013-12-31, 03:30
Dammit, half the channels have disappeared from the EPG again. They still all show in Channel List though. I even tried reverting to build 16442 but that hasn't helped.
Updated to the latest build and I was getting spammed with Connection Lost messages for TVheadend and Windows Media Service. I couldn't disable the latter so had to uninstall that but I'm still just getting the Connection Lost messages for TVHeadend and after rebooting the Windows Media service had reinstalled itself but at least I could disable it this time but it hasn't helped with TVHeadend.
The TVHeadend Web portal is now not showing any DVB adapters installed
It doesn't seem like the SMB path provides access to temp\xbmc.log so I have to use WinSCP to grab that, which is a bit of pain but no biggie.
http://xbmclogs.com/show.php?id=103786
I thought maybe the cascaded hub bug, which appeared to be fixed, had come back so I move the USB tuner to the first half of the hub. Now I can't even get the Web portal to load http://xbmclogs.com/show.php?id=103788
I also keep finding, probably after updating, that it's changed from 1280x720 to 1920x1080 and 1280x720 isn't available, the closet being 1280x1024. I need 1280x720 as that's all my TV supports, so when switching from my LCD monitor to my TV, nothing will display if it's set to 1920x1080.
