Full Version: OpenELEC Testbuilds for RaspberryPi Part 2
(2014-01-12, 13:00)dunkle Wrote: [ -> ](1) Audio now shows as PCM on my amp - I do seem to be getting 5.1 (steering around the room etc seems spot on) but it used to say Dolby Digital / DTS. I assume that teh PI / Openelec is just setting the raw audio and allowing the Amp to decode (much like PS3 did when that came out) and thus taking up less resources of the PI - is this correct ? Should I be worried ? Have I done something wrong
The settings are a bit different in Gotham - if you updated from Frodo you may have to set up some video/audio settings again.
Go to setting/system/audio and check passthrough is enabled, and DTS/AC3 are also enabled.
If there's still a problem the post output of "tvservice -a" after ssh-ing in.
(2014-01-12, 13:26)popcornmix Wrote: [ -> ]
Cheers for quick reply
I dont have option under audio for passthrough or DTS/AC3
I just have adudio output device (which is set as HDMI) and speaker configuration (listed as 5.1)
OpenELEC:~ # tvservice -a
PCM supported: Max channels: 8, Max samplerate: 192kHz, Max samplesize 24 bits
AC3 supported: Max channels: 6, Max samplerate: 48kHz, Max rate 640 kb/s.
DTS supported: Max channels: 7, Max samplerate: 96kHz, Max rate 1536 kb/s.
(2014-01-10, 14:25)popcornmix Wrote: [ -> ]dvdplayer doesn't currently support passthrough (it will play, but audio will be screetchy), so you will need to disable that for correct audio.
It may be worth testing if video keeps up with passthrough enabled, as it frees up some CPU.
Getting passthough working with paplayer/dvdplayer is something I am planning.
Add hdmi_stream_channels=1 to config.txt and that should fix passthrough.
AC3 was working fine for me but DTS was very slow.
Will give it a go, majority of my stuff seems to be DTS
Really confused my by library as well under Gotham
Its ending stuff long since deleted or removed from library
Some of the movies its adding I have not had on my netwrok since last week of December
Its also adding TV Shows from addons which again have been deleted
Ive checked my sources and they just show what I am currently using
(2014-01-12, 13:49)dunkle Wrote: [ -> ]Cheers for quick reply
You need to change the settings level to expert:
http://wiki.xbmc.org/index.php?title=XBM...ings_go.3F
(2014-01-12, 15:52)popcornmix Wrote: [ -> ]
Thats brilliant, missed that as using the confluence moddified skin, changed to normal, changed to advanced and changed back and all good
DTS now showing
Do I still need hdmi_stream_channels=1
(2014-01-12, 16:18)dunkle Wrote: [ -> ]Do I still need hdmi_stream_channels=1
Not normally when playing videos with omxplayer.
It just makes passthrough work from the Pi Audio sink, used by dvdplayer and paplayer.
(2014-01-12, 14:43)dunkle Wrote: [ -> ]Really confused my by library as well under Gotham
Did you temporarily try a Gotham build in December? Sounds like your current Gotham build has found a pre-existing MyVideos77 database which would have been created from your Frodo MyVideos75. Delete MyVideos77 (and 76 if it exists) and restart Gotham so that it re-upgrades your current video library.
See db versions for more details.
I've just got a Panasonic X60B Plasma TV (720P or to be precise 1024x768) to use with my RPi instead of my LCD monitor.
I was rather confused at first as I couldn't get any sound out of it and checked I got sound with my Xbox360 and tried swapping the HDMI lead but eventually I fixed it by commenting out these lines from config.txt, which I'd added before to force it to run at 720P:
#hdmi_ignore_edid=0xa5000080
#hdmi_group=2^M
#hdmi_mode=85^M
So now it works but it defaults to 1280x720@50hz and if I change it to 60hz, it also changes the resolution to 1366x768@60hz, with the hz greyed out, so is there any way to force it to 1280x720@60hz?
Does this setting just control the GUI anyway and will video content output at the correct refresh rate (the TV can run at both 50hz and 60hz and it's obviously desirable to have it match the source speed)? 1024x768 and 1920x1080p are options as well and I'm pretty sure when I was testing them, 1024x768 made it quite a bit brighter for some reason but I'll double check that again later.
(2014-01-12, 20:05)doveman2 Wrote: [ -> ]Does this setting just control the GUI anyway and will video content output at the correct refresh rate (the TV can run at both 50hz and 60hz and it's obviously desirable to have it match the source speed)? 1024x768 and 1920x1080p are options as well and I'm pretty sure when I was testing them, 1024x768 made it quite a bit brighter for some reason but I'll double check that again later.
Forcing the hdmi mode will make refresh rate switching impossible. Why are you forcing the mode?
Try removing those lines and just using "hdmi_drive=2"
Be aware that most content is 24fps, so you will only get limited benefit from refresh rate switching when 24Hz is not supported.
(2014-01-12, 20:05)MilhouseVH Wrote: [ -> ]
Not that I recall, All sorted now and running lieka dream though
V quick,
(2014-01-12, 20:09)popcornmix Wrote: [ -> ]Forcing the hdmi mode will make refresh rate switching impossible. Why are you forcing the mode?
I'm not forcing the mode, as I said I've commented out the lines that WERE doing so previously.
It must already be defaulting to hdmi_drive=2 as I get sound.
Checking my files, it seems that most of it is indeed 23.976fps, with my own TV recordings and iPlayer downloads being 25fps and DVDs 29.976fps. What I could do with MediaPortal is speed up the 23.976fps to 25fps and sync it with the TV running at 50hz and likewise with the 29.967fps DVDs, speed them up to 30fps and sync them with the TV running at 60hz, with MediaPortal able to switch the display/TV to the appropriate refresh rate, so I wonder if XBMC/OE can do something similar yet?
Problem today with latest MilhouseVH. Video freezes, could not ssh or yatze into xbmc. After a minute I could ssh again.
Here is a small capture of the log:
21:27:34 10068.306641 T:2814891088 NOTICE: Thread BackgroundLoader start, auto delete: false
21:27:34 10068.570312 T:2814891088 NOTICE: Previous line repeats 1 times.
21:27:34 10068.570312 T:2814891088 NOTICE: Thread JobWorker start, auto delete: true
21:27:38 10072.353516 T:2814891088 NOTICE: Previous line repeats 3 times.
21:27:38 10072.353516 T:2814891088 WARNING: GetIcon - Unknown nodetype requested videodb://tvshows/titles/59/1/?tvshowid=59
21:27:38 10072.551758 T:2588931152 NOTICE: Thread BackgroundLoader start, auto delete: false
21:27:44 10078.553711 T:3043213312 NOTICE: COMXPlayer: Opening: nfs://IP addres/export/Series-02/Almost Human/Almost Human - S01E04.mkv
21:27:44 10078.553711 T:3043213312 WARNING: CDVDMessageQueue(player):Tongueut MSGQ_NOT_INITIALIZED
21:27:44 10078.554688 T:2588931152 NOTICE: Thread OMXPlayer start, auto delete: false
21:27:44 10078.557617 T:2588931152 NOTICE: Creating InputStream
21:27:44 10078.760742 T:2588931152 NOTICE: Creating Demuxer
21:27:47 10081.166992 T:2588931152 NOTICE: Opening video stream: 0 source: 256
21:27:47 10081.214844 T:2588931152 NOTICE: Creating video thread
21:27:47 10081.215820 T:2555376720 NOTICE: Thread OMXPlayerVideo start, auto delete: false
21:27:47 10081.216797 T:2588931152 NOTICE: Opening audio stream: 1 source: 256
21:27:47 10081.219727 T:2588931152 NOTICE: Creating audio thread
21:27:47 10081.220703 T:2611131472 NOTICE: Thread OMXPlayerAudio start, auto delete: false
21:27:47 10081.220703 T:2588931152 NOTICE: Opening Subtitle stream: 2 source: 256
21:27:47 10081.277344 T:2588931152 NOTICE: OMXClock using audio as reference
21:27:47 10081.324219 T:2555376720 NOTICE: not a 3D movie
21:27:47 10081.325195 T:2555376720 NOTICE: Display resolution ADJUST : 1920x1080 (1920x1080) @ 24.00 - Full Screen (23) (weight: 0.002)
21:27:47 10081.441406 T:3043213312 NOTICE: Using GL_TEXTURE_2D
21:27:47 10081.462891 T:3043213312 NOTICE: GL: Using BYPASS render method
21:27:47 10081.462891 T:3043213312 NOTICE: GL: NPOT texture support detected
21:27:49 10083.325195 T:2555376720 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
21:28:44 10138.549805 T:2806502480 WARNING: Previous line repeats 5 times.
21:28:44 10138.549805 T:2806502480 NOTICE: ES: Client from 192.168.17.51 timed out
21:41:00 10874.239258 T:2546988112 NOTICE: Thread BackgroundLoader start, auto delete: false
21:41:06 10880.681641 T:2546988112 NOTICE: Thread JobWorker start, auto delete: true
21:41:52 10926.796875 T:2555376720 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
21:45:31 11145.873047 T:2806502480 WARNING: Previous line repeats 2146 times.
21:45:31 11145.873047 T:2806502480 NOTICE: ES: Client from 192.168.17.50 timed out
21:45:32 11145.928711 T:2555376720 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
The video freeze started at 21:40.
(2014-01-12, 04:28)bhamail Wrote: [ -> ]With the latest Milhouse Gotham build, I'm seeing repeated popups (every 10 seconds) with: Windows Media Center Client - linux arm Edition, Connection lost
Turns out that WMC being enabled by default may be a bug in XBMC and not the addon or OpenELEC.
