(2013-09-03, 20:05)popcornmix Wrote: [ -> ]I've updated the amplification/DRC commit in newclock3.
It now adds an audio settings option to
"Boost centre channel when downmixing"
The DRC scheme now works with stereo input, and also when xbmc's volume is less than maximum.
You can see the current amplification value (in dB) on the status overlay ('o' key).
If you add (to advancedsettings.xml):
<audio>
<limiterhold>100</limiterhold>
</audio>
It will behave less dynamically and won't back off the attenuation which may be better for normalised different volume levels.
Thanks popcornmix, look forward to trying it out
Hi all,
Tried your version of frodo. The problem i'm still having is that i have a wi pi wich is working some times if i have lucky. I think
it is a driver problem. Is there anything I can do to make it work again?
Thx
I've manage to narrow down the reason i can't boot with any Gotham builds. At boot i make i can get to xbmc spash screen but no further. I have full access with ssh and samba but cannot get it any further.
The problem appears to lie in the database folder in the userdata. Removing this folder will allow the pi to boot first time and as long as i don't update/add anything to the library i can reboot fine.
Not sure why frodo doesn't appear to have an issue with this? Tried with multiple Gotham builds and frodo builds and its only the Gotham that appears to have this issue.
soupboy
Gotham uses MyVideos76.db, and Frodo uses MyVideos75.db.
It's possible MyVideos76.db is corrupt and is stopping booting.
I'd suggest deleting it and rescanning. (If you delete it, I think it might convert MyVideos75.db to MyVideos76.db itsefl).
(2013-09-03, 23:33)RichG Wrote: [ -> ]Apologies if this is a known / discussed issue .....
I've been noticing some strange CPU utilisation while on the main Movie list page (viewed across SSH via 'top'). This is with latest rbej frodo build but I have also seen similar issue with recent gotham builds too. Library is accessed across a NFS share and datebase is MySQL on separate NAS. Default Confluence skin with scrolling plot disabled.
The utility of CPU seems highly dependent on what view is selected. In 'thumbnail' view I see CPU use of around 30%. This rises to 40% in 'list' or 'big list', to around 60% in the 'media info' views, right up to close on 90% when in 'thumbnail' view. However when I remain in 'thumbnail' view but select 'hide information' in the side panel options CPU drops to around 30% !!!
Why would the display of this info take such a large amount of processing? Especially with scrolling plot disabled. Is there any other settings that may effect this?
Read here:
http://forum.xbmc.org/showthread.php?tid=156320
Ignore Frodo, that will not be fixed. A number of issues with dirty rectangle processing have been fixed in Gotham.
If you spot problems in Gotham (i.e. high CPU when screen appears to be static) then report here:
http://forum.xbmc.org/showthread.php?tid=171784
Include screenshot with dirty rectangle visualisation enabled.
I think some omx patches or ffmpeg patches causing problem with Live TV.
Live Tv working fine with kernel 3.10.8 -24.08- here. (2 sec)
Newer not.
Openelec testing 3.1.7 live Tv works, startup time 8 sec
(all for my setup)
(2013-09-05, 17:17)popcornmix Wrote: [ -> ] (2013-09-03, 23:33)RichG Wrote: [ -> ]Apologies if this is a known / discussed issue .....
Read here:
Thanks - interesting. Will do some more testing in Gotham and will report if I see issues.
Last rbej gotham build: I have problems during playback of this file:
Format : AVI
Format/Info : Audio Video Interleave
File size : 400MiB
Duration : 41min
Overall bit rate : 1.350 Kbps
Writing application : VirtualDubMod 1.5.10.1 (build 2366/release)
Writing library : VirtualDubMod build 2366/release
Video
Format : MPEG-4 Visual
Format profile : Advanced [email protected]
Format settings, BVOP : 2
Format settings, QPel : No
Format settings, GMC : No warppoints
Format settings, Matrix : Personalizzato
Codec ID : XVID
Codec ID/Hint : XviD
Duration : 41min
Bit rate : 1.212 Kbps
Width : 624 pixel
Height : 352 pixel
Display aspect ratio : 16:9
Frame rate : 25,000 fps
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bit
Scan type : Progressivo
Compression mode : Con perdita
Bits/(Pixel*Frame) : 0.221
Stream size : 359MiB (90%)
Writing library : XviD 1.1.2 (UTC 2006-11-01)
Audio
Format : MPEG Audio
Format version : Version 1
Format profile : Layer 3
Mode : Joint stereo
Mode extension : MS Stereo
Codec ID : 55
Codec ID/Hint : MP3
Duration : 41min
Bit rate mode : Costante
Bit rate : 128 Kbps
Channel(s) : 2 canali
Sampling rate : 48,0 KHz
Stream size : 37,9MiB (9%)
Alignment : Audio allineato
Interleave, duration : 40 ms (1,00 frame)
Interleave, preload duration : 504 ms
It seems that the issue is with audio. The playback stops continously to recharge buffer...
Any hints?
(2013-09-05, 20:16)zoltan Wrote: [ -> ]Last rbej gotham build: I have problems during playback of
File looks okay. Can you upload it (or a sample of it that shows the problem) and give me a link.
