(2013-09-05, 20:01)Jönke Wrote: [ -> ]Yes ! Live tv in OE 3.1.7 is rock solid ! Not as fast channel change as in last working Gotham, but no other issue (with live tv)
Frodo will never have the fast channel change patch. It's not even in Gotham.
I'm still suspicious that the fast channel change patch in Gotham doesn't cause some issues (e.g. the black screen on channel change).
rbej
Have you removed fast channel change patch from Frodo build? It definitely will break it.
It that patch is removed can you back out any other live tv patches? Your Frodo build shouldn't be worse than OE 3.1.7.
(2013-09-07, 12:22)popcornmix Wrote: [ -> ] (2013-09-05, 20:01)Jönke Wrote: [ -> ]Yes ! Live tv in OE 3.1.7 is rock solid ! Not as fast channel change as in last working Gotham, but no other issue (with live tv)
Ok , can't really remeber which Gotham build that had the fastest Channel change without black screen issues but it had 1-2 sec less channel change time then OE 3.1.7 and the other Gotham stock build posted earlier ( not rbejs)
I can go back and test them again to find out if you want ?
Very happy with latest Frodo rbej build (04/09/13) so far.
No issues with Live TV (live or recordings) with MediaPortal 1.4 my side; except channel-changing stops playback (been like this for a while; don't really mind). Pretty fast, too.
DRC also working great! Didn't realize how much I wanted it until I had it :-) This certainly belongs in the Official builds.
Thanks guys!
I found a different between lastest build from frodo and gotham:
In Frodo, minutes jump forward or rewind is very slow and in gotham it is fast!
Updated Frodo Branch
- updated firmware
- remove "Fast Channel Change" patch
- [rendercapture] Fix passthrough rendercapture interface
- [rbp] Support grabbing just the video layer through rendercapture
http://netlir.dk/rbej/builds/
http://lysin.me/rbej
(2013-09-07, 23:28)rbej Wrote: [ -> ]Updated Frodo Branch
- updated firmware
Same issue, still no live-tv (OE 3.1.7 works)
(2013-09-05, 22:58)popcornmix Wrote: [ -> ] (2013-09-05, 20:16)zoltan Wrote: [ -> ]Last rbej gotham build: I have problems during playback of
It seems that the issue is with audio. The playback stops continously to recharge buffer...
File looks okay. Can you upload it (or a sample of it that shows the problem) and give me a link.
Here is a link for a file that give me the same problem:
http://www.easybytez.com/e4yzum5dudud/Gr...2.Kbps.rar
This file, instead, gives me any problem:
http://netload.in/dateibYAfD3fGLT.htm
Where is the difference?
