(2013-09-11, 17:06)popcornmix Wrote: [ -> ]I've also added https://github.com/xbmc/xbmc/pull/3233 which gives a useful speedup when entering the movies library.
Might be worth a new build.
Aaah, so THAT explains why first-time opening is always so much faster than subsequent opens! Thanks!
(2013-09-11, 17:06)popcornmix Wrote: [ -> ] (2013-09-11, 16:00)Jönke Wrote: [ -> ]@rbej
thanks but no live tv!
Did you remove the patches like popcornmix suggested?
http://forum.xbmc.org/showthread.php?tid...pid1502053
I've managed to reproduce the issue, and it is the "Avoid audio codec when in passthrough modes" commit.
I've removed it from frodo_rbp_backports for now.
Updated.
Please download today build again.
Yes that fixed it ! Live tv with Tvheadend client is back
Thanks !
-Issues noticed in this latest Rbej Frodo build, (no problem in OE 3.17)
- Live tv stalls when pvr-menys is open; Timeline -epg, pvr home meny etc
- No subtitles in live-hdtv (same as in all Gotham rpi builds)
(2013-09-11, 19:08)Jönke Wrote: [ -> ]- No subtitles in live-hdtv (same as in all Gotham rpi builds)
Has this ever worked on Pi?
Is this teletext subtitles or something else?
Does it work with TV recordings?
It´s working in rpi OE 3.1.7 (Frodo) but not in Gotham builds.
hdtv subtitles is dvb-sub and xbmc gui sees the subtitle and i can change and toogle language and so on.But xbmc never displays them on screen.
Yes, subtitles in hdtv recordings works
(2013-09-11, 19:29)Jönke Wrote: [ -> ]It´s working in rpi OE 3.1.7 (Frodo) but not in Gotham builds.
And it works on Gotham on other platforms?
Gotham FFmpeg 1.2
OpenElec 3.1.7 Frodo and FFmpeg 0.10.7
I think FFmpeg causes this sub issue on Rpi.
(2013-09-11, 18:14)rbej Wrote: [ -> ] (2013-09-11, 17:06)popcornmix Wrote: [ -> ]I've also added https://github.com/xbmc/xbmc/pull/3233 which gives a useful speedup when entering the movies library.
Updated.
Yup, performance when opening Movies list is now consistently faster. Awesome; thanks guys!
EDIT: TV Shows as well!
@rbej: make you a new gotham build with this feature?
YESS!!!
Live tv is working again (gotham!!!)
Great and lots of thanks!
Great update, thanks guys!
(2013-09-12, 14:52)stefan129 Wrote: [ -> ]rbej, any possibility this fix can be included in your next build (enable TLS/SSL support in ffmpeg)?
https://github.com/xbmc/xbmc/pull/3193
this should be included and supported since ages in the official OpenELEC builds (with external ffmpeg)
Skip/Seek on Myth (and presumably other PVR addons) is fixed!
I have not tested builds from earlier in September, so the fix may precede this build, but today's build is great.
