(2013-10-03, 17:16)theneverstill Wrote: [ -> ]Overall I am extremely impressed and want to give my appreciation and admiration to those who have contributed to take the build I tried to where it is today. Please let me know what I can do to help and also if you have any ideas as to my buffering issue.
Being able to build from source is useful.
http://wiki.openelec.tv/index.php?title=...spberry_Pi
It means you can run experiments with and without new patches to narrow down where problems appeares.
Methodical testing of new builds is useful.
Being told a specific new patch makes buffering over NFS worse with H264 and DTS passthough is useful information.
Being told buffering is worse now that it was a few months back is not so helpful.
There's a post in this thread from me to Milhouse describing the numbers in the codec info overlay and how they relate to cpu based underrun, and file I/O underrun.
Would be worth reading that if you can find it.
(2013-10-03, 18:08)popcornmix Wrote: [ -> ] (2013-10-03, 17:16)theneverstill Wrote: [ -> ]Overall I am extremely impressed and want to give my appreciation and admiration to those who have contributed to take the build I tried to where it is today. Please let me know what I can do to help and also if you have any ideas as to my buffering issue.
Will do, thanks. Which base should I start building from and when? Is there anything else that I can be looking for when testing other than just my buffering issue (ie any other known issues that I can help with)?
And what is the difference between the uploaded gotham and the one with your name appended to it?
And should I be using the advanced settings file that is hosted here (
http://netlir.dk/rbej/builds/) and here (
https://lysin.me/rbej/)?
Great work here !!!
I just installed the "5 minute" Openelec on USB/SD (with overclock) and updates to 3.2.2
https://www.youtube.com/watch?v=E_uHc6MIpTM
How i can install your newest Gotham here by holding (not loose) the USB/Overclock combination ??
(2013-10-03, 16:56)mcarni Wrote: [ -> ]Quote:Updated Gotham Branch
- sync with Gotham Popcornmix branch (newclock3)
http://lysin.me/rbej
maybe it was already noted but I cannot shutdwon anymore, it just keeps rebooting
M
[/quote]
This is very old Xbmc bug in Gotham. Still not fixed.
Thaks Rbej, I should have checked the bug report...but I was at work, in the middle of something else when i got struck by the possibility that this problem was occurring only to me...i feel somehow relieved now...
M
I wonder if this is the reason for theneverstill's buffering issue: "All movies ended up being in the neighborhood of 40GB".
Unless my quick math is wrong, this would require a transfer rate of about 45 Mb per second for a 2 hour movie. While that is well within the theoretical transfer rate of USB 2.0, I am pretty sure I saw benchmarks indicating actual transfer speeds (from fast USB keys) in the 20s. As I recall, the benchmarks were in the discussion about speeding up the Pi by using a USB key for the storage volume.
Re the shutdown bug — I have been sending a reboot command via ssh when I have this problem, assuming this is less likely to cause corruption than pulling the plug. Does that make sense. Is there a better way?
(2013-10-03, 20:21)allan87 Wrote: [ -> ]I wonder if this is the reason for theneverstill's buffering issue: "All movies ended up being in the neighborhood of 40GB".
You're mixing up your Mb and MB. A 40GB 2 hour movie would average 5.5MB/s, or about 55Mb/s (using 1MB=1000KB etc.). USB2 is rated at 480Mb/s, and 25MB/s read rate from USB should be possible on the Pi (with up to 12MB/s over wired ethernet). So a 40GB 2 hour movie shouldn't be a problem.
Though obviously the above is just the mathematical average bit rate, the movie could have some very high bit rate screnes which challenge a Pi, which is also why quoting the file size of the movie is pretty much irrelevant - the bitrate details from something like MediaInfo are more useful/relevant.
(2013-10-03, 20:37)allan87 Wrote: [ -> ]Re the shutdown bug — I have been sending a reboot command via ssh when I have this problem, assuming this is less likely to cause corruption than pulling the plug. Does that make sense. Is there a better way?
The "reboot" command would be preferable to pulling the plug, but until the bug is fixed there is no better solution.
Yes, I erred respecting the benchmark. The numbers were about 20 MB/s (not Mb)*. Still about 1/3 of the theoretical 480Mb/s, but ought to leave plenty of headroom for 45 Mb/s on average. (I think my math was right on the 45 Mb/s: 40,000 ÷ 120 ÷ 60 x 8, no?)
http://openelec.tv/forum/124-raspberry-p...?start=207
Unfortunately the Gotham build still has the issue where it stays on the EPG screen when changing channel and I have to press back twice to get to the picture again. This was fixed in the Frodo build I was using before.
I also have the problem where it doesn't reboot properly and just goes to a black screen but the RPi isn't shutdown as I can see the lights still flickering.
(2013-10-03, 23:36)allan87 Wrote: [ -> ]Yes, I erred respecting the benchmark. The numbers were about 20 MB/s (not Mb)*. Still about 1/3 of the theoretical 480Mb/s, but ought to leave plenty of headroom for 45 Mb/s on average. (I think my math was right on the 45 Mb/s: 40,000 ÷ 120 ÷ 60 x 8, no?)
We agree up until the "x 8" - I use x 10 when serial communication is involved... stop & start bits. Old habit. Dunno if it's more correct. But either way, ball park 5.5MB/s which is no problem for the Pi to read from USB - whether the Pi can smoothly display that amount of audio/video data is another matter.
Possibly my own fault but when I upgraded to the new Gotham version with the features from popcornmix the GUI only ran at 720p even though my advancesettings was set at 1080p. Anyone else have this happen?
(2013-10-03, 22:43)MilhouseVH Wrote: [ -> ] (2013-10-03, 20:21)allan87 Wrote: [ -> ]I wonder if this is the reason for theneverstill's buffering issue: "All movies ended up being in the neighborhood of 40GB".
allan87 & @MilhouseVH
Thanks for the replies and the suggestion to send media-info data. MilhouseVH was spot on - it reports the bitrate overall is 57,597 kb/s (this particular movie was 50GB). How do I tell what the bit rate is at specific scenes? Is there anything else I could check that would help?
Does anyone have a reply about if I should be including that advancedsettings.xml that is hosted on those two sites with the latest builds?
