2014-08-01, 19:37
I need Windows to use with DVBViewer. I only want a fanless motherboard with 5 SATA, I don't need HDMI or a lot of power. Maybe a ASRock AD2550R/U3S3 is a good idea, with 7 SATA+1 e-SATA and mini-itx (but too expensive, 160€).
(2014-08-01, 19:37)tocinillo Wrote: [ -> ]I need Windows to use with DVBViewer. I only want a fanless motherboard with 5 SATA, I don't need HDMI or a lot of power. Maybe a ASRock AD2550R/U3S3 is a good idea, with 7 SATA+1 e-SATA and mini-itx (but too expensive, 160€).
Quote:This module allows you connect any two of SATA III devices to the PCI Express Gen2 mini card slot through standard SATA cable
Half size mPCIe module can be used in full size mPCIe slot with bundled metal baffle.
Quote:Purchased a Mini-ITX motherboard with onboard WiFi, which I didn't need. This fit perfectly and gave me two more SATA ports for storage devices.
(2014-08-01, 17:02)Bjur Wrote: [ -> ]I have a problem I hope someone can help me with.Anyone?
When I watch TV I get stuttering and picture and sound doesn't match up. I can see the CPU is high.
I happens when I watch 720p video. When watching 1080i it's fine.
When I watch normal video 1080p files there's no problem whatsoever.
I'm using DSPlayer and LAV video.
My setup is: Intel Q1900-ITX.
In XBMC video I have:
Render method Pixel Shaders
decoding method: Software. Hardware Acceleration gives the same.
In LAV Video I have Intel Quicksync enabled.
Any help would be greatly appreciated. I had no problem with watching TV with and old E350 Zacate, so I'm very surprised why I can't get it to work.
(2014-06-05, 22:56)sub0ptimal Wrote: [ -> ]I tried both the ASRock Q1900-ITX and the Q1900B-ITX in a new Antec 110 ISK case.
Neither boards would post. With no fans in the case or on the motherboard, I can't tell if the problem is electrical or physical. The power LED comes on, but there is no video output (tried VGA, HDMI, DVI)
I'm stumped. After many years of builds, this is the first time I haven't been able to troubleshoot the problem. Maybe power supply in the Antec case?
(2014-08-08, 17:19)-DDD- Wrote: [ -> ]Maybe it's because the PSU isn't Haswell ready? I have an ISK110 and only Problems with H81 Asrock when i activate c6 States.
(2014-08-08, 17:45)Stereodude Wrote: [ -> ]Try a different PSU (to test)? Does it do anything different if you try to power it up without any RAM?
(2014-04-22, 22:51)fritsch Wrote: [ -> ]Yes - that I said. The 3225 has 16 EUs on its HD4000, that's enough power for Lanczos 3 Optimized.
Real: HD 4000: 16 EU
HD 4000 Baytrail: 4 EU <- that sucks, even the GPU in the Celeron 847 is better.
HD 2500: 6 EU
HD 3000: 12 EU
HD 2000: 6 EU
Source: wikipedia + http://hothardware.com/Reviews/Betting-O...ed/?page=2 <- for the baytrail and yeah my personal measurments make that clear, too.
