2014-01-31, 05:30
I am trying to make a view for pictures.
In the view with a list of picture files, when a list item is in focus, I want to display the picture and some $INFO[ListItem.Picture...] values. (ListItem.PictureHeadline, ListItem.PictureCaption, etc.)
When the list item is in focus, the ListItem.Picture... infolabels have no values. When I open the Info dialog for a picture, then return to the list of pictures, the ListItem.Picture... infolabels now have values for the picture I opened the Info dialog on.
I understand that it would be very slow to load all of the picture tags when the list is built, but the values could be obtained either when the listitem for a picture is put in focus, or when the value is asked for.
So, question 1: Is it possible to get the value of a ListItem.Picture... label when a picture in the list of pictures is in focus, without having to bring up the info dialog for that picture first.
I suspect the answer to question 1 is No.
I have tried to track down where in the C++ code I could add code to do this, but I have not been able to find a spot.
I would like to add something that says
When focus is set on a listitem
if (the listitem is a picture AND the info for the picture has not yet been loaded) load the picture info tags
or
When info for a picture is requested
if (the info for the picture has not yet been loaded) load the picture info tags
So, question 2 (if answer to Q1 is No): Is there some place in the C++ code I could add some logic to load picture info either when the info is asked for, or when a picture is focused on.
or
