2014-01-31, 17:28
i am using Ubuntu 12.10 - XBMCbuntu (GNU/Linux 3.5.0-22-generic i686)
i tried to get my remotecontrol from onkyo to work. It's labeled with rc-866. so i was running sudo dpkg-reconfigure lirc, i selected Windows Media Transceivers/Remote (all) in the next step windows media center v2 (usb) Direct/dish receiver.
But nothing happen. I cant use the libra remote control anymore or the onkyo remote. The receiver from Libra is labeled with Q11 receiver.
The first step would be to get the Libra rc back to work. Then, i could record the remote signals from the onkyo rc. But how?^^
dmesg | grep usb says:
[ 10.976157] input: Media Center Ed. eHome Infrared Remote Transceiver (195d:7002) as /devices/pci0000:00/0000:00:02.0/usb2/2-4/2-4:1.0/rc/rc0/input4
[ 10.976219] rc0: Media Center Ed. eHome Infrared Remote Transceiver (195d:7002) as /devices/pci0000:00/0000:00:02.0/usb2/2-4/2-4:1.0/rc/rc0
[ 11.168064] mceusb 2-4:1.0: Registered ItronIR Itron Infrared Transceiver with mce emulator interface version 1
restarting lirc failed
* Unable to load LIRC kernel modules. Verify your selected kernel modules in /etc/lirc/hardware.conf
my /etc/lirc/hardware.conf is
# /etc/lirc/hardware.conf
#Chosen Remote Control
REMOTE="Windows Media Center Transceivers/Remotes (all)"
REMOTE_MODULES="lirc_dev mceusb"
REMOTE_DRIVER=""
REMOTE_DEVICE="/dev/lirc0"
REMOTE_LIRCD_CONF="mceusb/lircd.conf.mceusb"
REMOTE_LIRCD_ARGS=""
#Chosen IR Transmitter
TRANSMITTER="Microsoft Windows Media Center V2 (usb) : Dish Receiver"
TRANSMITTER_MODULES="lirc_dev mceusb"
TRANSMITTER_DRIVER=""
TRANSMITTER_DEVICE=""
TRANSMITTER_LIRCD_CONF="dish/general.conf"
TRANSMITTER_LIRCD_ARGS=""
#Enable lircd
START_LIRCD="true"
#Don't start lircmd even if there seems to be a good config file
#START_LIRCMD="false"
#Try to load appropriate kernel modules
LOAD_MODULES="true"
# Default configuration files for your hardware if any
LIRCMD_CONF=""
#Forcing noninteractive reconfiguration
#If lirc is to be reconfigured by an external application
#that doesn't have a debconf frontend available, the noninteractive
#frontend can be invoked and set to parse REMOTE and TRANSMITTER
#It will then populate all other variables without any user input
#If you would like to configure lirc via standard methods, be sure
#to leave this set to "false"
FORCE_NONINTERACTIVE_RECONFIGURATION="false"
START_LIRCMD=""
REMOTE_SOCKET=""
TRANSMITTER_SOCKET=""
Sorry, for my bad english :/
thanks for your help,
MySt3rY
REMOTE_DRIVER=""
#Enable lircd
START_LIRCD="true"
LOAD_MODULES="true"
LIRCMD_CONF=""
START_LIRCMD=""
REMOTE_SOCKET=""
MySt3rY
