I have Minix mini x5 run xbmc(android) and Jynxbox android hd run xbmc(linux). Some vidoes run smoother on the Jynxbox than the Minix. Is it because xbmc(Linux) is always better than xbmc(android)/
Is there any way to fix this? I've just bought the Minix. I don't want to put it aside.
(2014-02-01, 22:32)curtqn Wrote: [ -> ]I have Minix mini x5 run xbmc(android) and Jynxbox android hd run xbmc(linux). Some vidoes run smoother on the Jynxbox than the Minix. Is it because xbmc(Linux) is always better than xbmc(android)/
Are you using Minix version XBMC?
I have been running xbmc 12.3 and Minix xbmc.
Then please try again with a
nightly build (wiki) of XBMC for Android (ARM).
(2014-02-02, 05:17)curtqn Wrote: [ -> ]I have been running xbmc 12.3 and Minix xbmc.
I have zero problems with custom ROM and Minix XBMC beta2.
On how to you, can find all details at Minix forum.
I feel the frodo 12.3 is a little better than the Minix Xbmc.
I also tried the newest nightly build. It's not stable.
