Hi guys,
I am able to see the subtitles just fine, it's just that every time I play the same video I need to download the subtitles each time.
So how can I save the subtitles so that when I come back to the same video I don't have to download again?
Tnx
Save them in a same folder where the video is
Yes, that option is checked in the configuration of the add-on, but I still need to do the process I described.
and is the subtitle saved there with the same name as the video?
EDIT:
Debug Log might tell us more
Thanks Amet,
I'll check as soon as I get home as gather more info.
I didn't find the subtitles for all the movies and tv shows I watched (around 8). I just found these two temp subtitle files (with the same content) from the last thing I watched:
/home/pi/.xbmc/userdata/addon_data/script.xbmc.subtitles/sub_tmp/1952269042.srt
/home/pi/.xbmc/userdata/addon_data/script.xbmc.subtitles/sub_stream/temp_sub.es.srt
Here is the log file:
http://pastebin.com/evT7Jqhc
Now I'll try this advice I found somewhere:
Go to Settings → Add-ons → Enabled Add-ons → XBMC Subtitles → Configure → Advanced Options → Deselect "Subtitle Download Folder Same As Movie" and then set a local path under "Set Custom Subtitle Download Path". You might also want to select "Auto download first sync subtitle" while you're there.
Edit: go elsewhere for icefilms support ... I am not interested anymore
