All of a sudden im getting ffmpeg errors.
Everything was fine a few days ago, I've recloned the git & started again, but im still getting this error.
make: *** No rule to make target `lib/ffmpeg/libavcodec/libavcodec.a', needed by `xbmc.bin'. Stop.
Im running ubuntu 12.04 & i ran ./configure with no options.
Any ideas ?
Thanks wsnipex
Problem Solved.
Despite this:
commit ad815563a3837bbd9ea73c3645af55ec56cacb9a
Author: Trent Nelson <[email protected]>
Date: Tue Feb 4 11:26:50 2014 -0700
[buildsys] Fix parallel build with static ffmpeg.
Probably there are still problems, I have the following:
LD xbmc.bin
lib/ffmpeg/libavformat/libavformat.a(rtmpdh.o): In function `dh_is_valid_public_key':
rtmpdh.c:(.text+0x30): undefined reference to `__gmpz_init2'
rtmpdh.c:(.text+0x40): undefined reference to `__gmpz_set_ui'
Im running ubuntu 13.10.
You compile with external ffmpeg?
No, I use the same debian/rules files present nightly xbmc-ppa.
I also had the same "undefined reference" issues, which I fixed by modifying Makefile:
I added to the "LIBS=" section, "-lgmp -lhogweed"
It works, thanks. It can be a permanent solution to put in git?
Greetings.
its already been fixed and fix is commited so this pr no longer applies.
which distribution is that? It works perfectly fine on ubuntu.
Seems like a problem with gnutls, which version do you have?
Looks like something in your most likely custom librtmp-dev?
My ubuntu:
ubuntu 13.10 (saucy) Kernel 3.13.0-031300-generic
with:
ii librtmp-dev 2.4+20121230.gitdf6c518-1 i386 toolkit for RTMP streams (development files)
ii librtmp0:i386 2.4+20121230.gitdf6c518-1 i386 toolkit for RTMP streams (shared library)
ii gnutls-bin 3.0.11+really2.12.23-1ubuntu4 i386 GNU TLS library - commandline utilities
ii libcurl3-gnutls:i386 7.32.0-1ubuntu1.3 i386 easy-to-use client-side URL transfer library (GnuTLS flavour)
ii libcurl4-gnutls-dev 7.32.0-1ubuntu1.3 i386 development files and documentation for libcurl (GnuTLS flavour)
ii libgnutls-dev 2.12.23-1ubuntu4 i386 GNU TLS library - development files
ii libgnutls-openssl27:i386 2.12.23-1ubuntu4 i386 GNU TLS library - OpenSSL wrapper
ii libgnutls26:i386 2.12.23-1ubuntu4 i386 GNU TLS library - runtime library
ii libgnutls28:i386 3.2.3-1ubuntu1 i386 GNU TLS library - main runtime library
ii libgnutlsxx27:i386 2.12.23-1ubuntu4 i386 GNU TLS library - C++ runtime library
ii libneon27-gnutls 0.29.6-3 i386 HTTP and WebDAV client library (GnuTLS enabled)
ii libneon27-gnutls-dev 0.29.6-3 i386 Header and static library files for libneon27 (GnuTLS enabled)
however, because adding -lgmp -lhogweed work?
My safe solution:
added in configure.in
AC_CHECK_LIB([gmp], [main],, AC_MSG_ERROR($missing_library))
AC_CHECK_LIB([hogweed], [main],, AC_MSG_ERROR($missing_library))
Neither of those are required by xbmc to compile... Nettle is definitely not anything to do with xbmc.
I have the same problem on my debian. I am doing standard ./bootstrap and ./configure without any switches. Works fine before (b6b5cee), now (15561b4) I have problems when linking:
http://pastebin.com/Hq2PcykX
Manually adding "-lgmp -lhogweed" to libs in generated Makefile also helps.
