Full Version: Astone A100
Hi all,
I have the Astone A100 android smart tv box on which I have installed the XBMC successfully. However, I want to install the following an add-on from the zip file: repository.tvp.zip. I have downloaded it on a USB flash drive and on an SD card. Every time I try to search for it through XBMC it can not see the USB flash drive or the SD card. Currently the Astone A100 is running on Android 2.3 and there is an option to upgrade it to Android 4 but I can not see to work out how.
Can some one advise on how can I transfer a zip file to be installed on XBMC.
Thank you,
