I'm moving my recorded shows around. I have my recorded TV being recorded directly to a small raid 1 array, and from there it gets renamed/moved to network storage on my clearos machine.
I have the watched folder setup in WMC and can play the recordings locally and through extenders, but it doesn't show up in xbmc recorded TV. In the config.XML I had to specify "smb://share" under the networkrecfolder.. If I leave it blank or put in "//share/" then it doesn't work.
Looking in the logs it shows:
2014/02/06 18:41:40.149 RecService> starting recording service - done
2014/02/06 18:41:40.154 Local 'Recorded tv' path: D:\Recorded TV\
2014/02/06 18:41:40.155 Format: NTFS
2014/02/06 18:41:40.155 Network 'Recorded tv' path: smb:\\192.168.1.61\Recorded_tv\
2014/02/06 18:41:40.157 Additional watched 'Recorded TV' folders:
2014/02/06 18:41:40.157 > \\forcefield\archived_dvr
The above log is from when I specified smb.. Any ideas? Can I add it manually somehow?
Is \\forcefield\archived_dvr a shared folder by everyone? Assuming it is, either attach a link to the whole log, or at least post the part of the log that has "GetRecordings>"
Not sure if this is related, but I've found that you should always share using IP address and not SMB name, i.e.
\\192.168.1.80\TV
and not
\\Server\TV
I also do the same with my Recorded TV Folder in the ServerWMC Application. I manually change it from \\Name\Recorded TV to \\IPADDRESS\Recorded TV. Otherwise, you'll have times when the name won't resolve and you won't be able to watch recordings..
That sort of sounds like it's dependent on name resolution within your home network etc and also depends if you have a mix of windows and non windows clients etc... I have 3 windows boxes running Windows 7 and Windows 8.1 and have never had an issue using host names.
Makes sense. As I indicated in another post, I use Windows 7 Media Center to record TV, but I watch it back on OpenELEC devices which run Linux. They were having lots of trouble with name resolution, but not anymore since I only use IP addresses now.
Yeah I always use IP addresses, sometimes for troubleshooting or out of frustration i'll use the full name temporarily. I have local DNS servers running on the network so it shouldn't matter too much.
Anyway I think I was having samba share permission issues before which I got sorted out.. I think. I just updated to the newest serverwmc version and it keeps giving me this error in the logs about the UNC path. The windows PC (straxus) has the recordings working just fine at the moment, where the openelec PC (192.168.1.141) shows nothing in the folder.
Here's the latest log snippet:
2014/02/07 17:20:37.976 HandleFolders ------------------------------------
2014/02/07 17:20:37.988 --- Share detail for 'D:\Recorded TV\':
2014/02/07 17:20:37.994 shared with: Everyone | ReadAndExecute, Synchronize | ContainerInherit, ObjectInherit | None | Allow
2014/02/07 17:20:37.994 shared with: NT AUTHORITY\Authenticated Users | DeleteSubdirectoriesAndFiles, Modify, Synchronize | None | None | Allow
2014/02/07 17:20:37.994 shared with: NT AUTHORITY\SYSTEM | FullControl | ContainerInherit, ObjectInherit | None | Allow
2014/02/07 17:20:37.994 shared with: BUILTIN\Administrators | FullControl | ContainerInherit, ObjectInherit | None | Allow
2014/02/07 17:20:37.995 shared with: CYBER\D | FullControl | ContainerInherit, ObjectInherit | None | Allow
2014/02/07 17:20:37.995 shared with: S-1-5-80-2913099195-3001839937-1914692661-1563395363-459793767 | DeleteSubdirectoriesAndFiles, Modify, Synchronize | ContainerInherit, ObjectInherit | None | Allow
2014/02/07 17:20:37.995 shared with: NT SERVICE\ehSched | DeleteSubdirectoriesAndFiles, Modify, Synchronize | ContainerInherit, ObjectInherit | None | Allow
2014/02/07 17:20:37.995 shared with: NT SERVICE\ehRecvr | DeleteSubdirectoriesAndFiles, Modify, Synchronize | ContainerInherit, ObjectInherit | None | Allow
2014/02/07 17:20:37.995 ----
2014/02/07 17:20:37.995 Local WMC 'RecTV' folder: 'D:\Recorded TV\', ShareStatus: OK
2014/02/07 17:20:37.997 Format: NTFS
2014/02/07 17:20:37.997 Stored Network 'Recorded tv' path:
2014/02/07 17:20:37.997 SMB: \\192.168.1.61\Recorded_TV\
2014/02/07 17:20:38.028 UNC: '\\192.168.1.61\Recorded_TV\', ShareStatus: OK
2014/02/07 17:20:38.029 -----
2014/02/07 17:20:38.030 Additional watched 'Recorded TV' folders:
2014/02/07 17:20:38.036 '\\192.168.1.8\archived_dvr' ShareStatus: Warning! this UNC path is not accessible by 'Everyone'
2014/02/07 17:20:38.036 HandleFolders -------------(DONE)----------------
2014/02/07 17:20:38.337 SocketServer> starting up SocketServer
2014/02/07 17:20:38.337 SocketServer> permission to access sockets granted
2014/02/07 17:20:38.341 SocketServer> socket object created
2014/02/07 17:20:38.342 SocketServer> started on port: 9080
2014/02/07 17:20:38.345 MaintenanceTimer> callback at 5:20 PM
2014/02/07 17:20:38.359 MaintenanceTimer> callback - complete
2014/02/07 17:21:24.890 Client: 'STRAXUS' addon Version: 0.2.93, Client OS: windows(6.2)
2014/02/07 17:21:24.893 Client: 'STRAXUS' running remotely: True
2014/02/07 17:21:24.896 Client: 'STRAXUS' path to Rec Folder: '\\192.168.1.61\Recorded_TV\'
2014/02/07 17:21:24.897 Received client request: STRAXUS|GetTimers
2014/02/07 17:21:25.861 Finished request GetTimers in 0.96s
2014/02/07 17:21:25.885 Received client request: STRAXUS|GetRecordings
2014/02/07 17:21:26.735 GetRecordings> Metadata read error on: \\192.168.1.8\archived_dvr\Legend of Korra, The (2012) [Family-Animation]\Season 1\The Legend of Korra - 1x09 - Out of the Past [LOW] [2012-06-09].wtv
2014/02/07 17:21:26.933 GetRecordings> Content protected file: True Detective, hiding: True
2014/02/07 17:21:26.987 GetRecordings> Metadata read error on: \\192.168.1.8\archived_dvr\Late Night with Jimmy Fallon (2009) [Talk Show]\Season 05\Late Night with Jimmy Fallon - 05x191 - Matthew McConaughey, Gisele Bundchen, Stephen Malkmus and the Jicks [SD] [2014-01-06].wtv
2014/02/07 17:21:27.065 GetRecordings> Metadata read error on: \\192.168.1.8\archived_dvr\Late Night with Jimmy Fallon (2009) [Talk Show]\Season 05\Late Night with Jimmy Fallon - 05x210 - David Beckham, David Steinberg, Busta Rhymes [LOW] [2014-01-31].wtv
2014/02/07 17:21:27.223 GetRecordings> Metadata read error on: \\192.168.1.8\archived_dvr\Marvel's Agents of S.H.I.E.L.D. (2013) [Sci-Fi]\Season 01\Marvel's Agents of S.H.I.E.L.D. - 1x06 - F.Z.Z.T. [720p] [2013-11-05].wtv
2014/02/07 17:21:27.437 GetRecordings> Completed for client STRAXUS, results:
2014/02/07 17:21:27.437 GetRecordings> Transfered: RecTV folder files: 0, watched files: 73
2014/02/07 17:21:27.437 GetRecordings> Ignored: local files: 0, temp files: 0
2014/02/07 17:21:27.437 GetRecordings> Weird files: no program: 0, no channel: 4, orphaned: 0
2014/02/07 17:21:27.437 GetRecordings> Misc: content protected: 3, icons: 38, instantRec: 0, metaDataReads: 73
2014/02/07 17:21:27.437 Finished request GetRecordings in 1.55s
2014/02/07 17:22:09.652 Client: '192.168.1.141' addon Version: 0.2.93, Client OS:
2014/02/07 17:22:09.652 Client: '192.168.1.141' running remotely: True
2014/02/07 17:22:09.652 Client: '192.168.1.141' path to Rec Folder: '//192.168.1.61/Recorded_TV/'
2014/02/07 17:22:09.654 Received client request: 192.168.1.141|GetTimers
2014/02/07 17:22:10.576 Finished request GetTimers in 0.92s
2014/02/07 17:22:10.595 Received client request: 192.168.1.141|GetRecordings
2014/02/07 17:22:11.023 GetRecordings error: System.FormatException: Invalid length for a Base-64 char array or string.
at System.Convert.FromBase64_Decode(Char* startInputPtr, Int32 inputLength, Byte* startDestPtr, Int32 destLength)
at System.Convert.FromBase64CharPtr(Char* inputPtr, Int32 inputLength)
at System.Convert.FromBase64String(String s)
at ServerWMC.Common.Crypto.DecryptStringAES(String cipherText, String sharedSecret)
at VDsoftware.MySettingsProvider.SettingsTemp.get_Credentials_Pwd()
at ServerWMC.Common.Utilities.PathUnc2Samba(String uncPath)
at ServerWMC.Worker.RecService.GetRecordings()
2014/0
Thanks for the help
When you use your pi, your password gets embedded in the path, and the password decrypt function we are using seems to be throwing an exception. I don't understand the error from the log file. Any chance there is a weird char you are using in your password?
It's not a pi, it's full openelec on an HTPC if it makes any difference.. I'm specifying the user credentials as "domain\user", could it be the backslash? I can try it without specifying the domain, or would putting in an encoded backslash (%5C) work?
Yes, don't include the domain (your shouldn't need it). The error was from the password though, you don't need to tell me what's in it - just whether it has a weird character.
Although, like I said, I don't understand the exception...
Hm. The password was 6 letters and two numbers, nothing all that strange. I changed the credentials to a different user without numbers in the password and the logs have stopped showing the error but I haven't had time to test it yet.
