2014-02-07, 07:13
hello,
been using XBMC since the modded-xbox days, been using Transparency since I built my HTPC two years ago - one of the best things to happen to XBMC! Thank you for making this great skin!
I recently setup my media room with a 2.35 screen/projector and was wondering if there is anything I can do to the skin to make it display in proper proportion on the super wide screen? I've searched and have not been able to find anything. My guess is I'm out of luck?
still works great, but it will zoom/crop the fanart background and the movie cases, icons, etc are stretched some.
If not available (without major internal reconstruction), then hopefully will be considered for the near future....
Thanks again for the skin.
