I sent it for publishing today, not sure if the kodi crowd will update it in the repository because there is no procedure defined for changing the mantainer of an addon.
I'll post here as soon as it get updated, If you cannot wait, maybe you can do a manual deploy of the addon:
https://github.com/m0r3/service.subtitle...s/releases
The new version 0.0.5 that fixes the "no subtitles found" issue has been released a few hours ago in the official addon repository.
If you had previous version installed, the update should be applied automathically, otherwise go to Settings/addons/search for updates
Hi, I'ts still broken. It don't show any result.
Hola, continúa roto, no me da resultados nunca.
(2015-03-19, 21:04)Julipo Wrote: [ -> ]Hi, I'ts still broken. It don't show any result.
It works but you should switch to Spanish the default language of the subtitles
(2015-03-19, 21:23)javixxx Wrote: [ -> ] (2015-03-19, 21:04)Julipo Wrote: [ -> ]Hi, I'ts still broken. It don't show any result.
Please, ensure you are using versión 0.0.5
I'll check why it's needed to set Spanish as default, should also work in english, however subtitulos.es is not the best place for downloading english subs.
If the problem persists please send me the name of the video file so I can debug if there is any parsing issue.
Hi!
I suppose you know that subtitulos.es is not working anymore.
The new website that continues is:
http://www.tusubtitulo.com/ .
If there is any possibility to update the addon, I would greatly appreciate it.
Thank You
(2015-07-12, 04:54)herver Wrote: [ -> ]Hi!
The new website that continues is: http://www.tusubtitulo.com/ .
Thank You
yes, that would be nice!
I'm the admin of the site. At this moment NO ONE is authorized to create any plugin or any services to download automatically subtitles from our page. At the moment that we"ll add that, we"ll inform. Any creation after and before of this post, will be against of our rules. If you have any question contact through : contacto@
tusubtitulo.com
(2015-07-17, 15:51)elbeborandy Wrote: [ -> ]I'm the admin of the site. At this moment NO ONE is authorized to create any plugin or any services to download automatically subtitles from our page. At the moment that we"ll add that, we"ll inform. Any creation after and before of this post, will be against of our rules. If you have any question contact through : contacto@tusubtitulo.com
What is the problem?
Any technical reason?
there´s also subswiki.com, it would be great to have that subtitle addon, at least until tusubtitulo allows the addon...
thanks obama
(2015-08-05, 00:25)laope Wrote: [ -> ] (2015-07-17, 15:51)elbeborandy Wrote: [ -> ]I'm the admin of the site. At this moment NO ONE is authorized to create any plugin or any services to download automatically subtitles from our page. At the moment that we"ll add that, we"ll inform. Any creation after and before of this post, will be against of our rules. If you have any question contact through : contacto@tusubtitulo.com
thanks obama
lol
Which one is the best for English ?
