2014-02-08, 20:33
I have Frodo 12.3 installed on my laptop with Win7 x64 & desktop with vista x64 for the last one month. The one on laptop is working fine but recently started having problem running on vista x64. When I run xbmc, windows task manager shows xbmc.exe with memory 3208K & it doesn't change. I reinstalled but still having the same problem! Please note that my computer setting hasn't been changed since the time it had been working. Here's the log file that I have:
13:25:43 T:6108 NOTICE: -----------------------------------------------------------------------
13:25:43 T:6108 NOTICE: Starting XBMC (12.3 Git:20131212-9ed3e58), Platform: Windows Vista SP2 64-bit, build 6002. Built on Dec 19 2013 (compiler 1600)
13:25:43 T:6108 NOTICE: Intel® Core2 Quad CPU Q8200 @ 2.33GHz
13:25:43 T:6108 NOTICE: Desktop Resolution: 1280x1024 32Bit at 60Hz
13:25:43 T:6108 NOTICE: Running with administrator rights
13:25:43 T:6108 NOTICE: Aero is enabled
13:25:43 T:6108 NOTICE: special://xbmc/ is mapped to: C:\Program Files (x86)\XBMC
13:25:43 T:6108 NOTICE: special://xbmcbin/ is mapped to: C:\Program Files (x86)\XBMC
13:25:43 T:6108 NOTICE: special://masterprofile/ is mapped to: C:\Users\Nighat\AppData\Roaming\XBMC\userdata
13:25:43 T:6108 NOTICE: special://home/ is mapped to: C:\Users\Nighat\AppData\Roaming\XBMC\
13:25:43 T:6108 NOTICE: special://temp/ is mapped to: C:\Users\Nighat\AppData\Roaming\XBMC\cache
13:25:43 T:6108 NOTICE: The executable running is: C:\Program Files (x86)\XBMC\XBMC.exe
13:25:44 T:6108 NOTICE: Local hostname: POKEMON
13:25:44 T:6108 NOTICE: Log File is located: C:\Users\Nighat\AppData\Roaming\XBMC\xbmc.log
13:25:44 T:6108 NOTICE: -----------------------------------------------------------------------
13:25:44 T:6108 NOTICE: Found 2 Lists of Devices
13:25:44 T:6108 NOTICE: Enumerated DirectSound devices:
13:25:44 T:6108 NOTICE: Device 1
13:25:44 T:6108 NOTICE: m_deviceName : {B39167D4-87FF-4C07-97EA-818095BEAD30}
13:25:44 T:6108 NOTICE: m_displayName : Speakers - Speakers (High Definition Audio Device)
13:25:44 T:6108 NOTICE: m_displayNameExtra: DirectSound: Speakers (High Definition Audio Device)
13:25:44 T:6108 NOTICE: m_deviceType : AE_DEVTYPE_PCM
13:25:44 T:6108 NOTICE: m_channels : FL,FR
13:25:44 T:6108 NOTICE: m_sampleRates : 44100
13:25:44 T:6108 NOTICE: m_dataFormats : AE_FMT_FLOAT,AE_FMT_AC3
13:25:44 T:6108 NOTICE: Device 2
13:25:44 T:6108 NOTICE: m_deviceName : {51B23FA0-9DC3-4000-B2D4-C20E30A2F02F}
13:25:44 T:6108 NOTICE: m_displayName : SPDIF - Digital Output Device (SPDIF) (High Definition Audio Device)
13:25:44 T:6108 NOTICE: m_displayNameExtra: DirectSound: Digital Output Device (SPDIF) (High Definition Audio Device)
13:25:44 T:6108 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
13:25:44 T:6108 NOTICE: Enumerated WASAPI devices:
13:25:44 T:6108 NOTICE: m_displayNameExtra: WASAPI: Digital Output Device (SPDIF) (High Definition Audio Device)
13:25:44 T:6108 NOTICE: m_sampleRates : 192000,96000,88200,48000,44100
13:25:44 T:6108 NOTICE: m_dataFormats : AE_FMT_AC3,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S32NE,AE_FMT_S32LE,AE_FMT_S32BE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
13:25:44 T:6108 NOTICE: m_displayNameExtra: WASAPI: Speakers (High Definition Audio Device)
13:25:44 T:6108 NOTICE: m_channels : FL,FR,FC,LFE,SL,SR,BL,BR
13:25:44 T:6108 NOTICE: m_sampleRates : 192000,96000,48000,44100
13:25:44 T:6108 NOTICE: m_dataFormats : AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE,AE_FMT_LPCM
13:25:44 T:6108 NOTICE: load settings...
13:25:44 T:6108 NOTICE: special://profile/ is mapped to: special://masterprofile/
13:25:44 T:6108 NOTICE: loading special://masterprofile/guisettings.xml
13:25:44 T:6108 NOTICE: Getting hardware information now...
13:25:44 T:6108 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:25:44 T:6108 NOTICE: Loaded playercorefactory configuration
13:25:44 T:6108 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
13:25:44 T:6108 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:25:44 T:6108 NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
13:25:44 T:6108 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
13:25:44 T:6108 NOTICE: Default DVD Player: dvdplayer
13:25:44 T:6108 NOTICE: Default Video Player: dvdplayer
13:25:44 T:6108 NOTICE: Default Audio Player: paplayer
13:25:44 T:6108 NOTICE: Disabled debug logging due to GUI setting. Level 0.
13:25:44 T:6108 NOTICE: Log level changed to 0
13:25:44 T:6108 NOTICE: Loading media sources from special://masterprofile/sources.xml
