Full Version: How to start LiveTV in Fullscreen without EPG ?
Hi together,
how is it possible to start from the mainscreen the LiveTV in the fullscreen, without any EPG window. ?
http://forum.xbmc.org/showthread.php?tid=183965
Depending on which skin you use you can use playpvrtv from the home screen, I'm using aeon nox 5 and that allows you to change the main menu entry for livetv.
