Full Version: Trailer paused when out of focus?
Hi, i need help debug my new skin...
The trailer on the main menu pauses when it goes out of focus.. or loading stream.. not sure which one..
Which control is related to this problem?
Play pause resume control doesn't seem to be the problem cause i tweaked it and it's still the same..
Here's the log
13:12:04 T:4248  NOTICE: -----------------------------------------------------------------------
13:12:04 T:4248  NOTICE: Starting XBMC (12.2 Git:20130502-32b1a5e), Platform: Windows Server 2008 SP2 32-bit, build 6002. Built on May  2 2013 (compiler 1600)
13:12:04 T:4248  NOTICE: Intel(R) Core(TM)2 Duo CPU     E4600  @ 2.40GHz
13:12:04 T:4248  NOTICE: Desktop Resolution: 1024x768 32Bit at 60Hz
13:12:04 T:4248  NOTICE: Running with administrator rights
13:12:04 T:4248  NOTICE: Aero is disabled
13:12:04 T:4248  NOTICE: special://xbmc/ is mapped to: S:\Program Files\XBMC
13:12:04 T:4248  NOTICE: special://xbmcbin/ is mapped to: S:\Program Files\XBMC
13:12:04 T:4248  NOTICE: special://masterprofile/ is mapped to: S:\Users\Administrator\AppData\Roaming\XBMC\userdata
13:12:04 T:4248  NOTICE: special://home/ is mapped to: S:\Users\Administrator\AppData\Roaming\XBMC\
13:12:04 T:4248  NOTICE: special://temp/ is mapped to: S:\Users\Administrator\AppData\Roaming\XBMC\cache
13:12:04 T:4248  NOTICE: The executable running is: S:\Program Files\XBMC\XBMC.exe
13:12:04 T:4248  NOTICE: Local hostname: WIN-MR0P5STU4H8
13:12:04 T:4248  NOTICE: Log File is located: S:\Users\Administrator\AppData\Roaming\XBMC\xbmc.log
13:12:05 T:4248  NOTICE: Found 2 Lists of Devices
13:12:05 T:4248  NOTICE: Enumerated DirectSound devices:
13:12:05 T:4248  NOTICE:     Device 1
13:12:05 T:4248  NOTICE:         m_deviceName      : {5EE11666-970F-433A-9BF9-892309E278A3}
13:12:05 T:4248  NOTICE:         m_displayName     : SPDIF - Digital Output Device (SPDIF) (High Definition Audio Device)
13:12:05 T:4248  NOTICE:         m_displayNameExtra: DirectSound: Digital Output Device (SPDIF) (High Definition Audio Device)
13:12:05 T:4248  NOTICE:         m_deviceType      : AE_DEVTYPE_IEC958
13:12:05 T:4248  NOTICE:         m_channels        : FL,FR
13:12:05 T:4248  NOTICE:         m_sampleRates     : 44100
13:12:05 T:4248  NOTICE:         m_dataFormats     : AE_FMT_FLOAT,AE_FMT_AC3
13:12:05 T:4248  NOTICE:     Device 2
13:12:05 T:4248  NOTICE:         m_deviceName      : {C3475A08-A780-4758-B2B5-0C2749A86295}
13:12:05 T:4248  NOTICE:         m_displayName     : HDMI - Digital Output Device (HDMI) (2- High Definition Audio Device)
13:12:05 T:4248  NOTICE:         m_displayNameExtra: DirectSound: Digital Output Device (HDMI) (2- High Definition Audio Device)
13:12:05 T:4248  NOTICE:         m_deviceType      : AE_DEVTYPE_HDMI
13:12:05 T:4248  NOTICE:         m_sampleRates     : 48000
13:12:05 T:4248  NOTICE: Enumerated WASAPI devices:
13:12:05 T:4248  NOTICE:         m_displayNameExtra: WASAPI: Digital Output Device (SPDIF) (High Definition Audio Device)
13:12:05 T:4248  NOTICE:         m_sampleRates     : 192000,96000,88200,48000,44100
13:12:05 T:4248  NOTICE:         m_dataFormats     : AE_FMT_AC3,AE_FMT_S24NE4,AE_FMT_S24LE4,AE_FMT_S24BE4,AE_FMT_S32NE,AE_FMT_S32LE,AE_FMT_S32BE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
13:12:05 T:4248  NOTICE:         m_displayNameExtra: WASAPI: Digital Output Device (HDMI) (2- High Definition Audio Device)
13:12:05 T:4248  NOTICE:         m_dataFormats     : AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_S16BE
13:12:05 T:4248  NOTICE: load settings...
13:12:05 T:4248  NOTICE: special://profile/ is mapped to: special://masterprofile/
13:12:05 T:4248  NOTICE: loading special://masterprofile/guisettings.xml
13:12:05 T:4248  NOTICE: Getting hardware information now...
13:12:05 T:4248  NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
13:12:05 T:4248  NOTICE: Loaded playercorefactory configuration
13:12:05 T:4248  NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
13:12:05 T:4248  NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
13:12:05 T:4248  NOTICE: No settings file to load (special://xbmc/system/advancedsettings.xml)
13:12:05 T:4248  NOTICE: Loaded settings file from special://profile/advancedsettings.xml
13:12:05 T:4248  NOTICE: Contents of special://profile/advancedsettings.xml are...
                                            <advancedsettings>
                                              <videolibrary>
                                                <dateadded>0</dateadded>
                                              </videolibrary>
                                              <video>
                                                <cleanstrings>
                                                  <regexp>[ _\,\.\(\)\[\]\-](webdl|EXTENDED|ac3|dts|Director&apos;s Cut|miniHDrip|Phil-Movie|Iran Movie|Iran-Movie|Singa-Movie|JDrama|JMovie|TWMovie|TwMovie|TW-Movie|CMovie|C-Movie|K-Movie|KMovie|Thai-Movie|Thai Movie|JMovie|Hk-Movie|HkMovie|720p|DVDRIp|miniBRRip|miniBRRIp|1080p|custom|dc|divx|divx5|dsr|dsrip|dutch|dvd|dvdrip|dvdscr|dvdscreener|screener|dvdivx|cam|fragment|fs|hdtv|hdrip|hdtvrip|internal|limited|multisubs|ntsc|ogg|ogm|pal|pdtv|proper|repack|rerip|retail|r3|r5|bd5|se|svcd|swedish|german|read.nfo|nfofix|unrated|ws|telesync|ts|telecine|tc|brrip|bdrip|480p|480i|576p|576i|720p|720i|1080p|1080i|hrhd|hrhdtv|hddvd|bluray|x264|h264|xvid|xvidvd|TEKS INDO|[TEKS INDO]|(TEKS INDO)|xxx|www.www|cd[1-9]|\[.*\])([ _\,\.\(\)\[\]\-]|$)</regexp>
                                                  <regexp>(\[.*\])</regexp>
                                                </cleanstrings>
                                              </video>
                                              <splash>false</splash>
                                              <alwaysontop>yes</alwaysontop>
                                              <gui>
                                                <algorithmdirtyregions>1</algorithmdirtyregions>
                                                <nofliptimeout>1000</nofliptimeout>
                                              </gui>
                                              <videolibrary>
                                                <backgroundupdate>true</backgroundupdate>
                                              </videolibrary>
                                              <musiclibrary>
                                              </musiclibrary>
                                              <tvshowmatching action="prepend">
                                                <regexp>[\._ \-]\[(\d{2,3})\]</regexp>
                                                <regexp>\[[Ss]([0-9]+)\]_\[[Ee]([0-9]+)([^\\/]*)</regexp>
                                                <!-- foo_[s01]_[e01] -->
                                                <regexp>[\._ \-]([0-9]+)x([0-9]+)([^\\/]*)</regexp>
                                                <!-- foo.1x09 -->
                                                <regexp>[\._ \-][Ss]([0-9]+)[\.\-]?[Ee]([0-9]+)([^\\/]*)</regexp>
                                                <!-- foo s01e01, foo.s01.e01, foo.s01-e01 -->
                                                <regexp>[\._ \-]([0-9]+)([0-9][0-9])([\._ \-][^\\/]*)</regexp>
                                                <!-- foo.103 -->
                                                <regexp>[\._ \-]p(?:ar)?t[._ -]()([ivxlcdm]+)([\._ \-][^\\/]*)</regexp>
                                                <!-- Pt.I, Part XIV -->
                                              </tvshowmatching>
                                            </advancedsettings>
13:12:05 T:4248  NOTICE: Default DVD Player: dvdplayer
13:12:05 T:4248  NOTICE: Default Video Player: dvdplayer
13:12:05 T:4248  NOTICE: Default Audio Player: paplayer
13:12:05 T:4248  NOTICE: Disabled debug logging due to GUI setting. Level 0.
13:12:05 T:4248  NOTICE: Log level changed to 0
13:12:05 T:4248  NOTICE: Loading media sources from special://masterprofile/sources.xml
13:12:05 T:2660  NOTICE: Thread CSoftAE start, auto delete: false
13:12:05 T:4248  NOTICE: Running database version Addons15
13:12:07 T:2160  NOTICE: Thread XBMC Peripherals start, auto delete: false
13:12:07 T:2916  NOTICE: Thread CRemoteControl start, auto delete: false
13:12:07 T:4940  NOTICE: Thread XBMC Peripherals start, auto delete: false
13:12:07 T:4248  NOTICE: Found screen: Generic PnP Monitor on AMD Radeon HD 5500 Series, adapter 0.
13:12:07 T:4248  NOTICE: Primary mode: 1024x768 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 640x480 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 640x480 @ 67.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 640x480 @ 72.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 640x480 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 720x480 @ 56.00 - Full Screen
13:12:07 T:4248  NOTICE: Previous line repeats 2 times.
13:12:07 T:4248  NOTICE: Additional mode: 720x480 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 720x480 @ 72.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 720x480 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 720x576 @ 56.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 720x576 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 720x576 @ 72.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 720x576 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 800x600 @ 56.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 800x600 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 800x600 @ 72.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 800x600 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1024x768 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1024x768 @ 70.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1024x768 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x720 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x720 @ 59.94 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x720 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x768 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x768 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x800 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x800 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x960 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x960 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x1024 @ 60.00 - Full Screen
13:12:07 T:4248  NOTICE: Additional mode: 1280x1024 @ 75.00 - Full Screen
13:12:07 T:4248  NOTICE: Checking resolution 15
13:12:08 T:4248  NOTICE: Running database version Addons15
13:12:08 T:4248  NOTICE: Running database version ViewModes4
13:12:08 T:4248  NOTICE: Running database version Textures13
13:12:08 T:4248  NOTICE: Running database version MyMusic32
13:12:08 T:4248  NOTICE: Running database version MyVideos75
13:12:08 T:4248  NOTICE: Running database version TV22
13:12:08 T:4248  NOTICE: Running database version Epg7
13:12:08 T:4248  NOTICE: initializing playlistplayer
13:12:08 T:4248  NOTICE: DONE initializing playlistplayer
13:12:10 T:3284  NOTICE: Thread XBPyThread start, auto delete: false
13:12:10 T:4248  NOTICE: Previous line repeats 3 times.
13:12:10 T:4248  NOTICE: initialize done
13:12:10 T:5664  NOTICE: Thread XBPyThread start, auto delete: false
13:12:10 T:4248  NOTICE: Running the application...
13:12:10 T:6004  NOTICE: -->Python Interpreter Initialized<--
13:12:10 T:3284  NOTICE: -->Python Interpreter Initialized<--
13:12:10 T:1204  NOTICE: -->Python Interpreter Initialized<--
13:12:10 T:5664  NOTICE: -->Python Interpreter Initialized<--
13:12:10 T:5816  NOTICE: -->Python Interpreter Initialized<--
13:12:10 T:5664  NOTICE:  StorageServer Module loaded RUN
13:12:10 T:5664  NOTICE: StorageClient-2.5.0 Starting server
13:12:10 T:5664  NOTICE: StorageServer-2.5.0 Storage Server starting S:\Users\Administrator\AppData\Roaming\XBMC\userdata\addon_data\script.common.plugin.cache\commoncache.db
13:12:15 T:4772  NOTICE: Thread Jobworker start, auto delete: true
13:12:15 T:4260  NOTICE: Thread XBPyThread start, auto delete: false
13:12:15 T:4248  NOTICE: Previous line repeats 6 times.
13:12:15 T:4248  NOTICE: ES: Starting event server
13:12:15 T:1016  NOTICE: Thread XBPyThread start, auto delete: false
13:12:15 T:5676  NOTICE: Thread CEventServer start, auto delete: false
13:12:15 T:5676  NOTICE: ES: Starting UDP Event server on 0.0.0.0:9777
13:12:15 T:5676  NOTICE: UDP: Listening on port 9777
13:12:15 T:2204  NOTICE: Thread CTCPServer start, auto delete: false
13:12:15 T:5816  NOTICE: Artwork Downloader: ## Service - Run at startup: False
13:12:15 T:5816  NOTICE: Artwork Downloader: ## Service - Delayed startup:  minutes
13:12:15 T:5816  NOTICE: Artwork Downloader: ## Service - Run as service: False
13:12:16 T:5228  NOTICE: Thread Jobworker start, auto delete: true
13:12:16 T:5228   ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Documents and Settings\user\My Documents\My Pictures\Picture\
13:12:16 T:5816  NOTICE: Artwork Downloader: ## Service - Time: :00
13:12:16 T:4260  NOTICE: -->Python Interpreter Initialized<--
13:12:16 T:3976  NOTICE: -->Python Interpreter Initialized<--
13:12:16 T:4116  NOTICE: -->Python Interpreter Initialized<--
13:12:16 T:5944  NOTICE: -->Python Interpreter Initialized<--
13:12:16 T:1484  NOTICE: -->Python Interpreter Initialized<--
13:12:16 T:5476  NOTICE: -->Python Interpreter Initialized<--
13:12:16 T:5100  NOTICE: -->Python Interpreter Initialized<--
13:12:16 T:1016  NOTICE: -->Python Interpreter Initialized<--
13:13:36 T:6036  NOTICE: Thread Jobworker start, auto delete: true
13:13:50 T:4304  NOTICE: Previous line repeats 3 times.
13:13:50 T:4304  NOTICE: Thread XBPyThread start, auto delete: false
13:13:50 T:4304  NOTICE: -->Python Interpreter Initialized<--
13:13:50 T:4304  NOTICE: YouTube-4.4.4
13:13:51 T:4304  NOTICE: CommonFunctions-2.5.1
13:13:52 T:4248 WARNING: Skin has invalid include: Dialogs_DoubleBar
13:13:52 T:4248 WARNING: Skin has invalid include: Dialogs_Label3
13:13:52 T:4248 WARNING: Skin has invalid include: Dialogs_Label4
13:13:53 T:4304  NOTICE: links: 'dict'
13:13:54 T:5396  NOTICE: Thread CGUIDialogCache start, auto delete: true
13:13:54 T:4248  NOTICE: DVDPlayer: Opening: http://r1---sn-2ugxh5a5-jcoe.googlevideo.com/videoplayback?sver=3&expire=1391950234&fexp=909715,906951,905024,919007,929437,902547,937417,913434,936910,936913&ms=au&id=o-AK0wwJWclEN5M_a_ZgXplkQ4ioSgZDgtxlKRrdRXmGoW&itag=22&ratebypass=yes&ipbits=0&mv=m&sparams=id,ip,ipbits,itag,ratebypass,source,upn,expire&source=youtube&upn=wCko0mihKEc&mt=1391926372&key=yt5&ip=111.68.25.118&signature=A155270AC8A8E91A1CA08041A21B5E239FF81682.EE788D1779C2DB5E9831BBB4657AC6B380AB5BE9|User-Agent=Mozilla%2F5.0+%28Windows+NT+6.2%3B+Win64%3B+x64%3B+rv%3A16.0.1%29+Gecko%2F20121011+Firefox%2F16.0.1
13:13:54 T:4248 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
13:13:54 T:5256  NOTICE: Thread CDVDPlayer start, auto delete: false
13:13:54 T:5256  NOTICE: Creating InputStream
13:13:56 T:5256  NOTICE: Creating Demuxer
13:13:56 T:3408  NOTICE: Thread CFileCache start, auto delete: false
13:13:57 T:5256  NOTICE: Opening video stream: 0 source: 256
13:13:57 T:5256  NOTICE: Creating video codec with codec id: 28
13:13:57 T:5256  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
13:13:57 T:5256  NOTICE: Creating video thread
13:13:57 T:5256  NOTICE: Opening audio stream: 1 source: 256
13:13:57 T:5256  NOTICE: Finding audio codec for: 86018
13:13:57 T:5380  NOTICE: Thread CDVDPlayerVideo start, auto delete: false
13:13:57 T:5380  NOTICE: running thread: video_thread
13:13:57 T:5256  NOTICE: Creating audio thread
13:13:57 T:5380  NOTICE:  fps: 24.000000, pwidth: 1280, pheight: 720, dwidth: 1280, dheight: 720
13:13:57 T:5380  NOTICE: Display resolution DESKTOP : 1024x768 @ 60.00 - Full Screen (16)
13:13:57 T:3880  NOTICE: Thread CDVDPlayerAudio start, auto delete: false
13:13:57 T:3880  NOTICE: running thread: CDVDPlayerAudio::Process()
13:13:57 T:3880  NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 44100, no pass-through)
13:14:01 T:5472   ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Documents and Settings\user\My Documents\My Pictures\Picture\
13:14:06 T:3880 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
13:14:12 T:5380 WARNING: Previous line repeats 1 times.
13:14:12 T:5380 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
13:14:14 T:3880 WARNING: Previous line repeats 1 times.
13:14:14 T:3880 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
13:14:17 T:5380 WARNING: Previous line repeats 1 times.
13:14:17 T:5380 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
13:14:18 T:3880 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
13:14:19 T:5380 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
13:14:38 T:4428  NOTICE: Thread Jobworker start, auto delete: true
13:14:38 T:5964  NOTICE: Previous line repeats 3 times.
13:14:38 T:5964   ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Documents and Settings\user\My Documents\My Pictures\Picture\
13:14:39 T:3868  NOTICE: Thread XBPyThread start, auto delete: false
13:14:39 T:3868  NOTICE: -->Python Interpreter Initialized<--
13:14:41 T:4368  NOTICE: Thread Background Loader start, auto delete: false
13:14:51 T:4388  NOTICE: Previous line repeats 1 times.
13:14:51 T:4388  NOTICE: Thread XBPyThread start, auto delete: false
13:14:52 T:4388  NOTICE: Previous line repeats 4 times.
13:14:52 T:4388  NOTICE: -->Python Interpreter Initialized<--
13:14:52 T:4140  NOTICE: Thread XBPyThread start, auto delete: false
13:14:52 T:2404  NOTICE: Previous line repeats 2 times.
13:14:52 T:2404  NOTICE: -->Python Interpreter Initialized<--
13:14:52 T:5884  NOTICE: -->Python Interpreter Initialized<--
13:14:52 T:3432  NOTICE: -->Python Interpreter Initialized<--
13:14:52 T:5544  NOTICE: -->Python Interpreter Initialized<--
13:14:52 T:5128  NOTICE: -->Python Interpreter Initialized<--
13:14:52 T:4140  NOTICE: -->Python Interpreter Initialized<--
13:14:52 T:4896  NOTICE: -->Python Interpreter Initialized<--
13:14:52 T:5964   ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Documents and Settings\user\My Documents\My Pictures\Picture\
13:14:53 T:5268  NOTICE: Thread XBPyThread start, auto delete: false
13:14:57 T:5268  NOTICE: -->Python Interpreter Initialized<--
13:15:58 T:4700  NOTICE: Thread Jobworker start, auto delete: true
13:15:58 T:4700   ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Documents and Settings\user\My Documents\My Pictures\Picture\
13:15:59 T:5372  NOTICE: Thread XBPyThread start, auto delete: false
13:15:59 T:5372  NOTICE: -->Python Interpreter Initialized<--
13:15:59 T:3528  NOTICE: Thread Jobworker start, auto delete: true
13:16:00 T:4356  NOTICE: Previous line repeats 1 times.
13:16:00 T:4356  NOTICE: Thread Background Loader start, auto delete: false
13:16:02 T:6136  NOTICE: Previous line repeats 1 times.
13:16:02 T:6136  NOTICE: Thread Jobworker start, auto delete: true
13:37:29 T:3880 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
13:37:30 T:5380 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
13:37:30 T:5256  NOTICE: CDVDPlayer::OnExit()
13:37:30 T:5256  NOTICE: DVDPlayer: eof, waiting for queues to empty
13:37:30 T:5256  NOTICE: DVDPlayer: closing audio stream
13:37:30 T:5256  NOTICE: Closing audio stream
13:37:30 T:5256  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
13:37:30 T:5256  NOTICE: Waiting for audio thread to exit
13:37:30 T:3880  NOTICE: thread end: CDVDPlayerAudio::OnExit()
13:37:30 T:5256  NOTICE: Closing audio device
13:37:30 T:5256  NOTICE: Deleting audio codec
13:37:30 T:5256  NOTICE: DVDPlayer: closing video stream
13:37:30 T:5256  NOTICE: Closing video stream
13:37:30 T:5256  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
13:37:30 T:5256  NOTICE: waiting for video thread to exit
13:37:30 T:5380   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
13:37:30 T:5380  NOTICE: thread end: video_thread
13:37:30 T:5256  NOTICE: deleting video codec
13:37:30 T:5256  NOTICE: CDVDPlayer::OnExit() deleting demuxer
13:37:30 T:5256  NOTICE: CDVDPlayer::OnExit() deleting input stream
13:37:30 T:4248  NOTICE: CDVDPlayer::CloseFile()
13:37:30 T:4248 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
13:37:30 T:4248  NOTICE: DVDPlayer: waiting for threads to exit
13:37:30 T:4248  NOTICE: DVDPlayer: finished waiting
13:37:30 T:5744  NOTICE: Thread Jobworker start, auto delete: true
13:40:31 T:5844  NOTICE: Thread XBPyThread start, auto delete: false
13:40:31 T:5844  NOTICE: -->Python Interpreter Initialized<--
13:40:40 T:5228  NOTICE: Thread Jobworker start, auto delete: true
17:47:38 T:3308  NOTICE: Previous line repeats 1 times.
17:47:38 T:3308  NOTICE: Thread CFileCache start, auto delete: false
17:47:42 T:1932  NOTICE: Thread CAlarmClock start, auto delete: false
17:47:45 T:1876  NOTICE: Thread Background Loader start, auto delete: false
17:47:45 T:2248  NOTICE: Thread Jobworker start, auto delete: true
17:47:48 T:5844  NOTICE: Previous line repeats 1 times.
17:47:48 T:5844 WARNING: The python script "S:\Users\Administrator\AppData\Roaming\XBMC\addons\screensaver.xbmc.slideshow\default.py" has left several classes in memory that we couldn't clean up. The classes include: WindowXMLDialog,Window,Monitor
17:48:28 T:1404  NOTICE: Thread CFileCache start, auto delete: false
17:49:09 T:4156  NOTICE: Previous line repeats 3 times.
17:49:09 T:4156  NOTICE: Thread Background Loader start, auto delete: false
18:09:46 T:3408  NOTICE: Thread Jobworker start, auto delete: true
23:57:52 T:4624  NOTICE: Previous line repeats 7 times.
23:57:52 T:4624  NOTICE: Thread CFileCache start, auto delete: false
23:58:09 T:3360  NOTICE: Previous line repeats 1 times.
23:58:09 T:3360 WARNING: XFILE::CCurlFile::CReadState::FillBuffer: curl failed with code 28
23:58:09 T:3360   ERROR: CCurlFile::CReadState::Open, didn't get any data from stream.
23:58:10 T:3360   ERROR: XFILE::CFileCache::Open - failed to open source <http://skin-git.googlecode.com/svn/trunk/frodo/addons.xml.md5>
23:58:16 T:3368  NOTICE: Thread CFileCache start, auto delete: false
23:58:54 T:1688  NOTICE: Previous line repeats 1 times.
23:58:54 T:1688  NOTICE: Thread Background Loader start, auto delete: false
05:57:56 T:2304  NOTICE: Thread Jobworker start, auto delete: true
05:57:58 T:4132  NOTICE: Thread CFileCache start, auto delete: false
06:02:07 T:4836  NOTICE: Previous line repeats 4 times.
06:02:07 T:4836  NOTICE: Thread Background Loader start, auto delete: false
07:13:47 T:3616  NOTICE: Thread Jobworker start, auto delete: true
07:13:53 T:1680  NOTICE: Previous line repeats 3 times.
07:13:53 T:1680  NOTICE: Thread XBPyThread start, auto delete: false
07:13:55 T:5280  NOTICE: Previous line repeats 7 times.
07:13:55 T:5280   ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Documents and Settings\user\My Documents\My Pictures\Picture\
07:13:56 T:2780  NOTICE: Thread XBPyThread start, auto delete: false
07:13:57 T:1680  NOTICE: -->Python Interpreter Initialized<--
07:14:00 T:5272  NOTICE: -->Python Interpreter Initialized<--
07:14:00 T:5368  NOTICE: -->Python Interpreter Initialized<--
07:14:00 T:3728  NOTICE: -->Python Interpreter Initialized<--
07:14:00 T:2548  NOTICE: -->Python Interpreter Initialized<--
07:14:00 T:5660  NOTICE: -->Python Interpreter Initialized<--
07:14:00 T:2780  NOTICE: -->Python Interpreter Initialized<--
07:14:00 T:4216  NOTICE: -->Python Interpreter Initialized<--
07:14:00 T:5196  NOTICE: -->Python Interpreter Initialized<--
07:14:23 T:4248   ERROR: CLocalizeStrings::ClearBlock: Trying to clear non existent block S:\Users\Administrator\AppData\Roaming\XBMC\addons\screensaver.xbmc.slideshow
07:14:53 T:4712  NOTICE: Thread Jobworker start, auto delete: true
07:32:06 T:4704  NOTICE: Previous line repeats 7 times.
07:32:06 T:4704   ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Documents and Settings\user\My Documents\My Pictures\Picture\
07:38:31 T:4360  NOTICE: Thread Jobworker start, auto delete: true
07:38:33 T:4996  NOTICE: Thread XBPyThread start, auto delete: false
07:38:35 T:4996  NOTICE: -->Python Interpreter Initialized<--
07:38:37 T:4996  NOTICE: YouTube-4.4.4
07:38:37 T:4996  NOTICE: CommonFunctions-2.5.1
07:38:41 T:4996  NOTICE: links: 'dict'
07:38:43 T:5420  NOTICE: Thread CGUIDialogCache start, auto delete: true
07:38:44 T:4248  NOTICE: DVDPlayer: Opening: http://r1---sn-2ugxh5a5-jcoe.googlevideo.com/videoplayback?upn=QZP_wlNenMo&key=yt5&mv=m&id=o-AHqI3XHV8hbpoU7JxXfgylIn637tRkQNZch-X7Qyh_Jr&ip=111.68.25.118&ratebypass=yes&mt=1391992615&sver=3&itag=43&fexp=903903,944900,914084,916612,937417,913434,936910,936913&source=youtube&expire=1392015602&ms=au&sparams=id,ip,ipbits,itag,ratebypass,source,upn,expire&ipbits=0&signature=8654D15F9DAA1E14F529FFDE85890D6DF80F259E.6ADC6027F51AE592648C6A795929822285834C3C|User-Agent=Mozilla%2F5.0+%28Windows+NT+6.2%3B+Win64%3B+x64%3B+rv%3A16.0.1%29+Gecko%2F20121011+Firefox%2F16.0.1
07:38:44 T:4248 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
07:38:44 T:5116  NOTICE: Thread CDVDPlayer start, auto delete: false
07:38:44 T:5116  NOTICE: Creating InputStream
07:38:44 T:4152  NOTICE: Thread CFileCache start, auto delete: false
07:38:44 T:5116  NOTICE: Creating Demuxer
07:38:46 T:5116  NOTICE: Opening video stream: 0 source: 256
07:38:46 T:5116  NOTICE: Creating video codec with codec id: 145
07:38:46 T:5116  NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: On2 VP8
07:38:46 T:5116  NOTICE: Creating video thread
07:38:46 T:5116  NOTICE: Opening audio stream: 1 source: 256
07:38:46 T:5116  NOTICE: Finding audio codec for: 86021
07:38:46 T:4484  NOTICE: Thread CDVDPlayerVideo start, auto delete: false
07:38:46 T:5116  NOTICE: Creating audio thread
07:38:46 T:5520  NOTICE: Thread CDVDPlayerAudio start, auto delete: false
07:38:46 T:5520  NOTICE: running thread: CDVDPlayerAudio::Process()
07:38:46 T:4484  NOTICE: running thread: video_thread
07:38:46 T:5520  NOTICE: Creating audio stream (codec id: 86021, channels: 2, sample rate: 44100, no pass-through)
07:38:46 T:4484  NOTICE:  fps: 24.000000, pwidth: 640, pheight: 360, dwidth: 640, dheight: 360
07:38:46 T:4484  NOTICE: Display resolution DESKTOP : 1024x768 @ 60.00 - Full Screen (16)
07:38:50 T:2932  NOTICE: Thread Jobworker start, auto delete: true
07:38:55 T:4360   ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Documents and Settings\user\My Documents\My Pictures\Picture\
07:38:56 T:6088  NOTICE: Thread Jobworker start, auto delete: true
07:38:56 T:6088  NOTICE: Previous line repeats 1 times.
07:38:56 T:6088   ERROR: XFILE::CDirectory::GetDirectory - Error getting C:\Documents and Settings\user\My Documents\My Pictures\Picture\
07:39:12 T:5520 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
07:39:13 T:4484 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
07:39:34 T:2856  NOTICE: Thread Jobworker start, auto delete: true
07:39:46 T:4484  NOTICE: Previous line repeats 1 times.
07:39:46 T:4484 WARNING: CRenderManager::FlipPage - timeout waiting for flip to complete
07:39:46 T:4484 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
07:39:51 T:5520 WARNING: Previous line repeats 47 times.
07:39:51 T:5520 WARNING: CDVDMessageQueue(audio)::Get - asked for new data packet, with nothing available
07:39:51 T:4484 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
07:39:54 T:5116 WARNING: Previous line repeats 30 times.
07:39:54 T:5116  NOTICE: CDVDPlayer::OnExit()
07:39:54 T:5116  NOTICE: DVDPlayer: eof, waiting for queues to empty
07:39:54 T:5116  NOTICE: DVDPlayer: closing audio stream
07:39:54 T:5116  NOTICE: Closing audio stream
07:39:54 T:5116  NOTICE: CDVDMessageQueue(audio)::WaitUntilEmpty
07:39:54 T:5116  NOTICE: Waiting for audio thread to exit
07:39:54 T:5520  NOTICE: thread end: CDVDPlayerAudio::OnExit()
07:39:54 T:5116  NOTICE: Closing audio device
07:39:54 T:5116  NOTICE: Deleting audio codec
07:39:54 T:5116  NOTICE: DVDPlayer: closing video stream
07:39:54 T:5116  NOTICE: Closing video stream
07:39:54 T:5116  NOTICE: CDVDMessageQueue(video)::WaitUntilEmpty
07:39:54 T:4484 WARNING: CRenderManager::FlipPage - timeout waiting for previous frame
07:39:54 T:4484 WARNING: CDVDMessageQueue(video)::Get - asked for new data packet, with nothing available
07:39:54 T:5116  NOTICE: waiting for video thread to exit
07:39:54 T:4484   ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
07:39:54 T:4484  NOTICE: thread end: video_thread
07:39:54 T:5116  NOTICE: deleting video codec
07:39:54 T:5116  NOTICE: CDVDPlayer::OnExit() deleting demuxer
07:39:54 T:5116  NOTICE: CDVDPlayer::OnExit() deleting input stream
07:39:55 T:4248  NOTICE: CDVDPlayer::CloseFile()
07:39:55 T:4248 WARNING: CDVDMessageQueue(player)::Put MSGQ_NOT_INITIALIZED
07:39:55 T:4248  NOTICE: DVDPlayer: waiting for threads to exit
07:39:55 T:4248  NOTICE: DVDPlayer: finished waiting
thanks
Anyone?
Still cant figure it out..
Also, im using win server 2008 r2
But it does not have audio output (i couldnt find compatible driver for my speaker)
Is this related somehow?
