2014-02-10, 23:23
I can't figure out why after deleting userdata folder and parent xbmc folder and then reinstalling xbmc via linux terminal by pointing to stable repository link (ppa:team-xbmc/ppa) I am still ending up with unstable version 13.0 rather than Frodo 12.3...help please!
specifically,
I have deleted userdata folder and also the parent xbmc folder via WinSCP, followed by the terminal commands:
sudo apt-get remove xbmc
sudo apt-get autoremove
sudo apt-get purge xbmc
The above seems to delete XBMC from the system; however, when I type the following...
sudo apt-get install python-software-properties pkg-config
sudo apt-get install software-properties-common
sudo add-apt-repository ppa:team-xbmc/ppa
sudo apt-get update
sudo apt-get install xbmc
...the XBMC version is still 13.0 alpha when I reboot. shouldn't it be 12.3 since that is still the latest stable version?
What am I doing wrong??
thanks for any help!!!
specifically,
sudo apt-get update
