Is it possible to start VDR with a delay of 4-5 sec?
From time to time I have the problem that the VDR doesn't found a dvb-device because is not mountet
until VDR starts... that also happend if I rebbot the HTPC... So I thought it could help if VDR starts with a delay...
I start vdr with upstart triggered by a dvb-ready event fired by udev when it detects the device.
So the answer is yes of course, if you don't want to use the mostly old fashioned startup scripts provided by the various distros.
thanks, for answer...
so i had a look into the system and I only have the vdr.conf...
If I understand right, I've to make an upstart script for VDR instand of the vdr.conf and there
I've to build in the dvb-ready event fired by udev... right
If it is something like this I've to for a HowTo...
My udev rule:
#DVB
SUBSYSTEM=="dvb" , KERNEL=="dvb0.frontend0", ACTION=="add", RUN+="/sbin/initctl --quiet emit --no-wait dvb-ready"
upstart:
description "vdr"
start on (local-filesystems
and net-device-up IFACE=lo
and dvb-ready)
stop on runlevel [!2345]
nice -1
pre-start script
while [ ! -e /dev/dvb/adapter0/frontend0 ]
do
sleep 1
done
end script
script
su -c /usr/local/bin/runvdr xbmc > /var/vdr/vdr.log 2>&1
end script
Thanks for sharing...
I'll try...
You could also add that check for the dvb adapter in your vdr startup script in /etc/init.d/vdr
My startvdr looks like this (I've got 2 dvb adapters so waiting for the second to be ready)
startvdr()
if [ "$ENABLED" != "0" ] ; then
# only start vdr if there is no other instance running
if start-stop-daemon --start --startas $DAEMON --test \
--name $(basename $DAEMON) --pidfile $PIDFILE >/dev/null
then
while ! [ -e /dev/dvb/adapter1/frontend0 ]; do
sleep 1s;
done
Complete file:
http://paste.ubuntu.com/6918149/
The
dynamite-plugin allows to start independ to the dvb devices. They will be added by the plugin to the vdr when they come. The vdr can be started even without any dvb device.
Gerald
Today I had a litle bit time think about the udev-rule and upstart script.
So I think I've to do as follow:
create a udev.rule /etc/udev/rules.d/set_VDR_ready.rule
#DVB
and create a upstart script /etc/init/vdr.conf
description "vdr-upstart"
and dvb-ready)
nice -1
pre-start script
do
sleep 1
done
end script
script
su -c /usr/sbin/runvdr > /var/vdr/vdr.log 2>&1
end script
I changed
su -c /usr/sbin/runvdr because I found the runvdr only in this path...
The older Series 7 Board from Asrock had the Bug, that they don't detect the PCIe Card 100%, some Bios Versions detected it only sometimes. Maybe this Patch won't help then, when the BIOS doesn't recognize
the Card properly?!
But i would like to have this Delay also, cause i think my Setting in OE (Start Confluence on TV Screen) doesn't work because the vdr/vnsi isn't ready when xbmc wants to go into TV Screen.
So I've test it yesterday and it works perfect for me...
thanks again to FernetMenta...
