Full Version: PseudoTV Live settings2.xml
So I want to start out by saying pseudoTV live is awesome. But there isn't much in the way of set up interactions and help for Mac users. Understandable as most XBMC users are PC or Linux users but I was wondering if somebody out there could help me find my setting2.xml file.
In the instructions it says "edit your settings2.xml" without identifying its location at all. I looked under Users>[my username]>Library>Application Support>XBMC>[PseudoTVLive Add-on]>resources but was only able to find a regular settings.xml. I was able to find a thread that said you will not have a settings2.xml till you open the program for the first time but I have opened "PseudoTV live" many times and had no luck generating a settings2.xml. Finally, I am giving up and just straight up asking what is likely a n00b question "Where is the settings2.xml file located in OS X?"
Sorry if I am missing any pertinent details you may need to help me but just ask and I'll let you know .
I am running a MacMini 2012 model with 4GB of ram and a 2.3 Ghz Intel Core i5 processor and OS X version 10.7.5
Thank you for your help.
(2014-02-11, 18:52)Jenesis83 Wrote: [ -> ]So I want to start out by saying pseudoTV live is awesome. But there isn't much in the way of set up interactions and help for Mac users. Understandable as most XBMC users are PC or Linux users but I was wondering if somebody out there could help me find my setting2.xml file.
There is a whole thread about pseudo live tv,Post there and someone with mac will help you
Jenesis83 you can find it in Library/Application Support/XBMC/Userdata/addon_data/script.pseudotv
The path is the same for Windows and Mac OS after XBMC
