2014-02-12, 00:03
Pages: 1 2
2014-02-12, 00:03
2014-02-12, 00:05
2014-02-12, 00:35
(2014-02-12, 00:05)Wanilton Wrote: [ -> ]Yes, it´s possible, look this thread:
http://forum.xbmc.org/showthread.php?tid=185026
Thanks so much. Will take a look
2014-02-12, 19:10
Does anyone know where I can download some audio codec icons/images? So I can replace the default ones of MQ5?
2014-02-12, 23:14
Google.
2014-02-15, 19:14
2014-02-16, 11:17
Can you share it devilshura?
2014-02-16, 11:35
(2014-02-15, 19:14)devilshura Wrote: [ -> ]There are many image size that you found on web.To use them,you need to adjust size and position to math in MQ5 layout.
For sample,I made it from the pack of many skin(e.g.Nox color icon/Purity).Some images from web search and my own creation.
Sounds great devilshura
+1 if you can share these icons/images
And, how would I adjust size/position within MQ5 layout please?
2014-02-16, 13:31
Yes i can share the flags-pack.This is a link for zip-file that include many flag i changed.
Flags.zip
For instant uses.You can get it as a new theme, from this thread.
[MEDIA CASE] Aeon MQ 5
Flags.zip
2014-02-16, 14:44
(2014-02-16, 13:31)devilshura Wrote: [ -> ]Yes i can share the flags-pack.This is a link for zip-file that include many flag i changed.
Flags.zip
Thank you very much.
2014-02-16, 16:35
Flags.zip
Brilliant looks so much better to the eye many thanks mate
2014-02-17, 00:13
Flags.zip
Many thanks. I installed the Gloss_color flags theme and the icons/images look awesome
For some reason though, each of my home screen menus went black afterwords though - any ideas?
I had to reset the MQ5 to default settings
2014-02-17, 07:02
2014-02-17, 11:23
Thanks for this devilshura. After I reset the skin and then re-chose you theme I have since been able to correct the fanart to display on my menu screen.
Couple of questions if you could help.
1) My duration of movie in nfo is displayed as '1hr 35m' - however in XBMC it is displayed as 95mins - any idea why this happening? can i change it so that duration is displayed in 'hrs mins' format?
2) Can duration be displayed at the moment of the wall page with other media info? (to the right of % watched for example)
Thanks in advance,
litfoo
Thanks in advance,
litfoo
2014-02-17, 11:44
(2014-02-17, 11:23)litfoo Wrote: [ -> ]Thanks for this devilshura. After I reset the skin and then re-chose you theme I have since been able to correct the fanart to display on my menu screen.
Thanks in advance,
litfoo
I think for some question you asked.MarcosQui the skin owner,must know it best.
Pages: 1 2
