Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13
Hi. Bluecop and ksosez's ESPN addon has been half broken for some time now. Thanks to the helpful work of people like locomot1f it has stayed somewhat alive, but there were still always problems with the userdata files and such. Because of that I decided to take this addon, strip it down to being only the still functioning parts, and make sure the parts that do work, work flawlessly.
After taking the appropriate steps of contacting both the xbmc addon team and attempting to contact the original creator (Bluecop) I have now added it to the official XBMC repo.
Enjoy.
hi I am having trouble with espn. when I open a stream it says script failed espn3. can u please help me out. newbee. I am using a gbox .
Great, thanks. Does this work for just ESPN 3, or will it work with ESPN and/or ESPN 2?
(2014-02-12, 17:57)dfa82 Wrote: [ -> ]Great, thanks. Does this work for just ESPN 3, or will it work with ESPN and/or ESPN 2?
Login is not working at all right now as far as I understand, so it should just be ESPN3.
My question is if this plugin would allow spoofing like previous ones did where you could use the userdata.xml file to make it think you were on a partner ISP?
still not working for me. any of you guys in Canada. I'm getting script failed error espn3. any help please.
Weldone Pythoneer. way-to-go you have been a great job ROMAN
Did you get this approved for the XBMC repo? I can add it to mine if it doesn't get on there soon.
I am very sorry for the long delay. I just got now got this approved for the official repo. Make sure to let me know if you experience any problems. Enjoy.
seems to be working just fine here!
just installed it from, the main repo
bang up job, Romans, for keeping this addon going!
