I made the move to serverWMC for my backend and I seem to have a problem. I can get it to work if its on the host machine but will not work over the network.
Hopefully my logs can give an insight to my problem.
XBMC Log
http://pastebin.com/DY5gtC1m
ServerWMC
http://pastebin.com/2utK251f
So mediabrowser which is running the the same machine as swmc is working. But a networked windows machine is not, right?
2014/02/11 22:53:29.531 Finished request OpenLiveStream in 3.55s
2014/02/11 22:53:29.604 Received client request: Alienware|StreamStartError|\\XEON\Users\Public\Recorded TV\TempSWMC\LiveTV_Alienware_ATSC_44.1_2014_02_11_22_53_25.ts
2014/02/11 22:53:29.604 StreamStartError> client 'Alienware' reports error opening stream, will close stream down
2014/02/11 22:53:29.604 StreamStartError> client 'Alienware' path to stream file: '\\XEON\Users\Public\Recorded TV\TempSWMC\LiveTV_Alienware_ATSC_44.1_2014_02_11_22_53_25.ts'
Can you confirm that your path is shared correctly and accessible from the ALIENWARE machine? \\XEON\Users\Public\Recorded TV\TempSWMC\
Also there seem to be a few other things going on - sometimes a video stream cant be identified before we stop parsing, another time there are unidentified audio tracks.
If you have some WTV files in the "Recorded TV\TempSWMC\Saved for Debug" folder, can you upload them to krusty's google drive for analysis?
https://drive.google.com/folderview?id=0...sp=sharing
Im particularly interested in seeing the ones for channels 4.1 or 9.1... but would also be good to see channel 44.1
Oh another thing to confirm with you, is that no other devices or systems are also trying to use your network HD Home Run tuner? Ie, WMC on this "XEON" PC has exclusive access to the tuner?
Also, are you running one instance of serverwmc?
Thank you for your help, it turns out that my other computers in the house did not have the network credentials to view the shares.
I have mediabrowser server running on my xeon machine.
I have only one instance of serverwmc running.
My goal was to have one backend for xbmc (HTPC) and mediabrowser for all other occassions
After the network shares were established all is well.
