2014-03-22, 22:31
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75
2014-03-22, 22:37
Are you using the latest zip or git file from post #1? Wayne made a fix earlier today (as you can see in the posts just before yours) and it has fixed it for me.
2014-03-22, 22:46
(2014-03-22, 22:31)patseguin Wrote: [ -> ]I am getting a script failed error in Aeon Nox. Is this due to 6.0.5 of the script? Because it worked fine until only recently.
My car is broken can you fix it?
You get my point?
Debug log
2014-03-23, 17:27
Rolled back to 6.04. No script error.
2014-03-23, 18:42
2014-03-23, 21:06
[/quote]
Can you please try 6.0.6? I released that early yesterday, but it's not in the approved repositories yet.
..wayne..
[/quote]
This solved my problem with 'exceptions.IndexError', thanks!
..wayne..
[/quote]
2014-03-23, 21:06
(2014-03-22, 22:37)LEDFan Wrote: [ -> ]Are you using the latest zip or git file from post #1? Wayne made a fix earlier today (as you can see in the posts just before yours) and it has fixed it for me.
Nope but that fixed it!
2014-03-23, 23:10
(2014-03-23, 17:27)thewarm Wrote: [ -> ]Rolled back to 6.04. No script error.
me too..
6.05 say "script error"..
i'm using frodo 12.3
2014-03-24, 00:56
WayneD,
I am running the following
Windows 7, Gotham beta 2, Aeon Nox 4.1.9.6 (latest Git) and TV Show Next Aired 6.0.6 (latest from the git) I now get a message saying TV Next Aired script failed.
everything was ok until 1 of 2 things happened - I updated to the latest Git of Aeon Nox and/or TV Next Aired updated itself.
Here is my log file - http://pastebin.com/BnCkVzLn
I also tried to reset and update (from the script settings) but it fails half way through.
Just a mute point - I also had this problem, like a few others running Aeon Nox (with the repo update of TV Next Aired) that's why I downloaded the latest from the Git.
Edit: Have rolled back to version 6.0.4 for now and everything is OK.
2014-03-24, 01:58
Getting script error with the latest TV Show Next Aired from git and gotham beta2.
It seems to get stuck on Dad's Army
NOTICE: script.tv.show.next.aired: ### getting series & episode info for #76342 - Dad's Army
10:18:49 T:2780 ERROR: EXCEPTION Thrown (PythonToCppException) : -->Python callback/script returned the following error<--
Error Type: <type 'exceptions.ValueError'>
Error Contents: (22, 'Invalid argument')
File "E:\XBMC\portable_data\addons\script.tv.show.next.aired\default.py", line 1367, in <module>
NextAired()
File "E:\XBMC\portable_data\addons\script.tv.show.next.aired\default.py", line 166, in __init__
self.show_gui()
File "E:\XBMC\portable_data\addons\script.tv.show.next.aired\default.py", line 1116, in show_gui
self.update_data(update_after)
File "E:\XBMC\portable_data\addons\script.tv.show.next.aired\default.py", line 566, in update_data
tid = self.check_show_info(tvdb, tid, current_show, prior_data)
File "E:\XBMC\portable_data\addons\script.tv.show.next.aired\default.py", line 899, in check_show_info
dt = dt.astimezone(tz.tzlocal())
File "E:\XBMC\portable_data\addons\script.tv.show.next.aired\dateutil\tz.py", line 101, in dst
if self._isdst(dt):
File "E:\XBMC\portable_data\addons\script.tv.show.next.aired\dateutil\tz.py", line 141, in _isdst
return time.localtime(timestamp+time.timezone).tm_isdst
ValueError: (22, 'Invalid argument')
2014-03-24, 02:08
Hello Wayne,
I think there is bug in way how you construct date format (line 53). Currently it looks like
Why is there lower()?
For my region xbmc.getRegion('dateshort') returns %d-%m-%Y but lower function changes it to %d-%m-%y which is quite different (4 digits year vs. 2 digits year).
DATE_FORMAT = xbmc.getRegion('dateshort').lower()
2014-03-24, 02:29
(2014-03-24, 00:56)bolter Wrote: [ -> ]I also tried to reset and update (from the script settings) but it fails half way through.The show it fails on is Captain Scarlet and the Mysterons, which has shows right near the 1967 unix ordinal cutoff. My prior fix to the dateutil code (for systems that don't like negative time.localtime() values) apparently doesn't handle a date that is right right near the start of the year, but bumped back into the prior year by an offset. I've tweaked the code a bit more to make sure that it can't possibly go negative.
Note that the only reason this doesn't affect 6.0.4 is that it does the weeding of the older episodes a little differently than the new code.
(2014-03-24, 01:58)Steveb Wrote: [ -> ]It seems to get stuck on Dad's ArmyThis is the same issue.Code:ValueError: (22, 'Invalid argument')
Both are fixed in the latest git and zip files. Thanks for the reports.
..wayne..
2014-03-24, 02:49
(2014-03-24, 02:29)WayneD Wrote: [ -> ](2014-03-24, 00:56)bolter Wrote: [ -> ]I also tried to reset and update (from the script settings) but it fails half way through.The show it fails on is Captain Scarlet and the Mysterons, which has shows right near the 1967 unix ordinal cutoff. My prior fix to the dateutil code (for systems that don't like negative time.localtime() values) apparently doesn't handle a date that is right right near the start of the year, but bumped back into the prior year by an offset. I've tweaked the code a bit more to make sure that it can't possibly go negative.
..wayne..
Cheers mate, that did the trick!
2014-03-24, 02:49
(2014-03-24, 02:08)bambi73 Wrote: [ -> ]Yeah, the code was doing that before I got to it. I figure that the prior author(s) liked the brevity in the 2-digit years and decided to force it. I personally use the Next-Aired setting that turns on the nicer dates, which either omits the current year entirely, or uses a 4-digit year for other years.Why is there lower()?Code:DATE_FORMAT = xbmc.getRegion('dateshort').lower()
I'm hesitant to change the default format to be different than what it is without some discussion somewhere about it first. I personally would be fine changing it to a 4-digit year, but then I don't ever see it.
..wayne..
2014-03-24, 02:54
(2014-03-24, 02:49)Steveb Wrote: [ -> ](2014-03-24, 02:29)WayneD Wrote: [ -> ](2014-03-24, 00:56)bolter Wrote: [ -> ]I also tried to reset and update (from the script settings) but it fails half way through.The show it fails on is Captain Scarlet and the Mysterons, which has shows right near the 1967 unix ordinal cutoff. My prior fix to the dateutil code (for systems that don't like negative time.localtime() values) apparently doesn't handle a date that is right right near the start of the year, but bumped back into the prior year by an offset. I've tweaked the code a bit more to make sure that it can't possibly go negative.
..wayne..
All fixed my end.
Thanks WayneD
